Joe's Airfix 1/48 Spitfire Mk1
The cockpit tub is complete. All OOB. Once everything is dry and the final pieces applied, I will pop the pilot into his seat. Good thing I dry fitted the pilot before the seat went in, because I had initially missed Airfix's instruction to remove the rudder pedals if using the figure. Should get the fuselage zipped up soon.
Nice work joe , Osgood has had a shave after his marmite sandwich !
Cheers Tony. Yep, he's been warned about acting like that in the officers mess.
Very nice Joe. The instrument panel has come out well.
Cheers Steve. the instrument panel is the kit decal with liberal amounts of decal softener solution.
Nice progress Joe, pilot and office are looking great (y)
Cheers Steven.
Ah, I did wonder why my chap didn't fit. Anyway, Osgood is looking tip top old boy.
Yeah, it's not obvious the way they have annotated it. Cheers Colin.
Update time having spent time at my bench today.
This is where I left it last time. I had pre-painted the area where the radiator fits, so I can mask off the radiator grills which are painted and pin washed. I've also masked the silver landing gear leg joins.
Wing root problems on both sides, it was a mission to get the two wings to meet at the same dihedral. After this I also discovered that Airfix had once again not made a step obvious for fitting the closed canopy. I needed to remove parts of the side wall to sit flush with the cockpit door. This resulted in some light damage to the fuselage sides which I had to spend time on rectifying.
I to have been having a bit of fun with wing roots. I wonder if it's the way many manufacturers connect their wings to the fuselage, as in, the same way?
Coming on nicely Joe!!
I also spotted the step for fitting the closed canopy completely by chance - just have to make sure that I actually do it!. I also have to trim the tail place in the same way to get the rudder on! Talking about not making it easy!! :cautious:
ATB
