Another step of the build completed
I’m happy with how it’s looking so it will be a gloss coat next before I tackle the dreaded Eduard transfers
I switched from 1/72 to 1/48 as I thought the larger scale would be easier…..this is the PE rear view mirror, scalpel blade for scale
Thanks for looking
Geoff.
Cheers StevenNice paintwork so far Geoff - all looking good, cheers![]()
Thanks Steve, I’m pleased with how it’s turned out so farThats turned out well Geoff. Colors are spot on.
Thank you JoeVery nice work Geoff.
Thanks Neil, yep there’s no getting away from themYeah, I think all they do is add more even tinier parts than 1/72
Good work so far, looking forward to seeing the transfers wrestled into submission
I just used Mr Setter applied directly to the model where the transfer was to be placed then applied the transfer onto it. Once I was happy with its position I pressed it down with a damp cotton bud and then left it alone overnight.Nice work on the decals Geoffdid you use 'mr softer' as well or only 'mr setter'? Cheers
Hopefully NeilThey really do look painted on. Looking forward to the clear coat now which should make them really pop.
Cheers Joe, I’m pleased with how that have turned outDecals look superb Geoff, looking very nice
Thanks SteveGlad it all turned out well Geoff. Looks very nice indeed
