Steven's Eduard 1/48 F6F-3 Hellcat
Thanks guys - means a lot 🙏
A few more things done, first masked and glued in the rear-windows,
The tail-wheel on the Hellcat was retractable, so I had to do some cutting for in-flight-mode.
Left : gear down configuration - Right : cutting a hole in the fuselage, the tail-wheel lost some weight as well,
The tail-wheel is now retracted,
For my steel-rod-display-stand I need a bit of meat inside, so I glued in some balsa wood with a hot-glue-gun,
Next the fuselage-halves were glued together,
I also glued the wings together,
That's all for now, thanks for reading - Cheers :coffee:🥵
Looks to have fitted together well Steve. Nice work and I cant stop admiring your pilot.
HI Steven yes your hellcat is looking good very nice work on the poilot looks very detatailed he does keep this comin as im followin along sir
chrisb
Thanks guys 🙏
Had some time after work to mount the wings - the fit was quite loose (at least for an Eduard kit) so I tried to expand the wing profile with balsa wood, this worked to some extend but it still needs a bit of filler.
I cut the lines of the trim-tabs for the elevator and rudder with a razor saw,
With the wings and horizontal stabilizer glued in position it starts to look like a plane.
I didn't realize the Hellcat was such a big plane, it's almost as big as my P-47D Thunderbolt.
That's all so far, thanks for watching - Cheers ☕
I didn't realize the Hellcat was such a big plane; it's almost as big as my P-47D Thunderbolt.
I compared my P47 with the Spitfire, and that, and the F6 really are beasts, aren't they?
Coming along nicely, it's going to look good in flight. I think I'll borrow the balsa idea for my Mig build.
