Does your compressor have a moisture trap? A clear shot glass looking device attached to the regulator with a plunger you push up from the bottom of the trap to drain any trapped moisture.
Oh poop!New compressor time, no ifs, no buts, no coconuts.
It's nowhere near any seam or the drain plug.Is the leak from a welded seam or around the drain plug fitting. If it's around a seam or in the body of the receiver tank then Leyton O is 100% right, ditch it immediately or a nasty incident could occur. If the leak is from the threads where the drain plug screws in then a good clean MAY work.
Good luck.
Can't remember exactly when I bought it, but probably 6 or 7 years ago. Having said that, I've done no maintenance apart from draining it once last year, so probably the leak is my fault.As above mate, don't use it, its just not worth the risk when using any type of HPA (High Pressure Air) device.
Can I ask how long you have had the compressor? as I've just bought the same one myself....[Gulp!]
Summat to remember for my next compressor!At the end of an airbrushing session I turn off the compressor and always release the pressure by unscrewing the drain plug in the bottom of the tank. I then leave the plug out until the next time I use it. By removing the drain plug water is blown out and by leaving the plug out any moisture in the tank has a chance to evaporate. When you remove the plug you can see water on it. No water=no rust.
Good advice mate, I'll try to remember it for mine, cheersAt the end of an airbrushing session I turn off the compressor and always release the pressure by unscrewing the drain plug in the bottom of the tank. I then leave the plug out until the next time I use it. By removing the drain plug water is blown out and by leaving the plug out any moisture in the tank has a chance to evaporate. When you remove the plug you can see water on it. No water=no rust.
