Compressor leak.
Gern
Hi guys. Just noticed I have a tiny leak in my AS 186 compressor tank. Looks like it has rusted through from the inside. Is there any way to fix this or do I need a new compressor?
Does your compressor have a moisture trap? A clear shot glass looking device attached to the regulator with a plunger you push up from the bottom of the trap to drain any trapped moisture.
Yep! But I've never seen any water in it.
Is the leak from a welded seam or around the drain plug fitting. If it's around a seam or in the body of the receiver tank then Leyton O is 100% right, ditch it immediately or a nasty incident could occur. If the leak is from the threads where the drain plug screws in then a good clean MAY work.
Good luck.
Good luck.
It's nowhere near any seam or the drain plug.
If I'm understanding correctly the leak is from the main body of the tank, if it is don't risk using it as I have seen the damage that a full size one in a panel shop can do when it let's go.
As above mate, don't use it, its just not worth the risk when using any type of HPA (High Pressure Air) device.
Can I ask how long you have had the compressor? as I've just bought the same one myself....[Gulp!]
Always a good idea to periodically undo the drain plug to let any moisture that has collected out.
I also release the tank pressure after each session by pulling the ring on the rear safety valve.
Can't remember exactly when I bought it, but probably 6 or 7 years ago. Having said that, I've done no maintenance apart from draining it once last year, so probably the leak is my fault.
At the end of an airbrushing session I turn off the compressor and always release the pressure by unscrewing the drain plug in the bottom of the tank. I then leave the plug out until the next time I use it. By removing the drain plug water is blown out and by leaving the plug out any moisture in the tank has a chance to evaporate. When you remove the plug you can see water on it. No water=no rust.
Summat to remember for my next compressor!
Good advice mate, I'll try to remember it for mine, cheers
