A question for you all if I may
Peter57
Peter
Devon, UK
I was a great (not necessarily good but very keen!) plastic kit modeller back about 40 years ago. But, well life and my buisness moved on but now I'm retired, which as a self employed garage owner I didn't do till I was 73 so you can't call me a quitter!, I'm beginning to think more and more about taking the hobby up again. I'm currently interested in 1/350 scale warships and I'm looking longingly at the Black Cat resin kits BUT I've never built anything other than polystyrene or used any photo etch. Also, post retirement, as further evidence of how Mother Nature feels about car mechanics I suffered a stroke. Oh nothing too bad but my vision, while perfect straight ahead or to the left has packed up totally on my right. All peripheral vision gone, in fact all awareness that is a world to my right has gone which is harder to explain! Oh, and don't panic, I can no longer drive!
But I've wittered on long enough now so my question. Is, as I suspect, a resin kit with pe going to be beyond my abilities and, if so, what manufacturer of 1.350 military ships or even what kit might make a good "come back" for me?
Thank you for listening.
Hi and welcome mate, enjoy the forums, lots of good peeps and some great info on here. Recently retired myself and I have received huge amount of help off the forum to get me back into the hobby. I would say just go for it, try not to worry too much about it, just get out there, buy a kit that takes your fancy, and start building, gluing, painting, etc.
What type of ships are you interested in, eg: civilian, military, etc?
Tamiya do a few 1:350 ships and are usually well regarded when it comes to a good fit, good instructions, etc. but theres plenty of manufacturers now that do 1:350 scale, Airfix, Trumpeter, Dragon, Takom, AFV Club, Border, etc......check out our very own Scale Model Shop - see link below:
SMS 1:350 ships
Keep us updated on your progress, pics are always welcomed.... 8-)
SMS 1:350 ships
Thank you for the reply! I have been looking at the 1/350 scale Black Cat kits but I am beginning to think they may be a bit beyond me? So my second choice is the Trumpeter 1/350 HMS Calcutta. The fact that it's a slightly unusual and less famous ship appeals to me. And at least it's mostly plastic which I am, or at least was, used to should be a plus?
But there are some "extras" I would like so what do you use to glue resin (or even pe) to plastic?
Yes, I AM that out of touch!
Plastic kits stick together with styrene cement but that won't stick resin or PE. For that you need CA - super glue. PVA will work but the join is much less secure. There are other glues on the market but not sure how good they are.
Trumpeter kits are usually pretty good. They often have a large parts count - lots of itty-bitty pieces to drive you mad.
I try to avoid PE if I'm honest, most of it is far too small and fiddly for my sausage like fingers, Lol.
But on the few occasions I have used it I have used CA (super glue) and I also bought some PE specific glue, (see pic) which is probably just CA but with a different label on the bottle!
Maybe it's me but when I was still working (as a garage owner/mechanic) I never found the so-called super glues much help (even for internal trim)? But then again in my mcase I could usually get the MIG out! But because of the welding stuff I'm happy to admit I have very little experience of super glues.
So you don't see it as better than any other contact adhesive? Please don't see that as my being critical!
I'm honestly just a newbie trying to learn.
It's actually a supercharged PVA, dries fairly quickly with a strong bond.
I use it to hold small parts in situ because its tacky.
Never been a fan of pe..... Too fiddly I find and I work in 1/35......dread to think what a tiny scale ship would be like
Where's Bob when we need him lol..... He'd have all the answers
Hi Peter, as said in your introduction post you've picked the right hobby to return to except plastic ships in the scale or below can be quite a challenge but good therapy if you have the patience, eye coordination and a pair of steady hands. In the past 40 years these plastic ships kits have gone madly detailed and with aftermarket stuff to enhance them further. I for one believe PE railings are a must for the scale you have chosen. For the rest of the PE just compare them with the original plastic part and see if needs replacing. A steady hand is a requisite when attaching these fiddly parts I'm afraid but there are tools that can help hold the part to the attachment area as you apply the glue. The choice of glue for PE is CA or PVA...these glues are basically to get a firm grip with as little applied with the rule that they never be touched again. We're all old enough not to take it into the bathtub for sea trials.😅 CA works using capillary or placing a dot but not much room for adjusting as it latches on when the parts meet, any movement after lessens the bonding and PVA does the same except it take a while to cure depending on how thick a solution is applied so you might need to hold it in place longer. Excess glue can be cleaned off on both, besides using a CA debonder I wicker with a sharp tooth pick towards the part until it disappears. For PVA you wipe away residue carefully with a damp paint brush.
There should be a post somewhere here that shows how to apply CA or work with PVA on PE. Another aftermarket detail that will look good is rigging. That's another can of worms. 😅 There are some good stuff in the net for these.
Now all I've said depends on how far you want to test yourself. Building a ship stock standard can be satisfaction too. But I must warn you some new kit brands give you basic railing PE to either do or do without. Happy modeling.
Richard aka Wabble
Does it stick to resin though?
Very small parts, yes. It may not be suitable for heavier parts that block the center areas from curing as it doesn't have chemical reactions to do it and relies on evaporation.
Wabble
