Andrew's 1/72 Airfix P-40B Warhawk (Pearl Harbour)
You havent been nicking it from the chippy have you andrew !?
I resent that inference that I stole it!! I paid good money for what came in it!!!
Seriously though, when the kids were younger they used to deliver the local free newspapers, so we always had plenty of spare paper lying around and whilst I still have a bit left, it dawned on me that the properties of the paper chippies use - slightly grease proof - would be great for protecting the area and spraying over. Plus a light plain background is great to spray over. So when we get a chippy I just keep the clean sheets back.
Then someone in the local Facebook group was selling a 250 sheet pack of what's basically the same paper for £10........so I had that off them too.
........Nicking the paper.....a scandalous suggestion!! 😉😁😂🤣
Ok chaps...so a bit of an update...from last weekend's work:
  • A lot of very large sprue gates made removing parts a a bit challenging but nothing that a bit of care could not deal with.....
  • Joined the fuselage...I normally paint first and then join the two halves but as not much will be seen at this scale, I thought I would give it a go to save some time and it worked well. Might try it on the next build to see if it works...accepting that not all fuselage types are built in this style, with the cockpit fixed to the bottom of the wing.
  • The famous under engine radiator/air intake 'chin' was a bit misshapen and a not a great fit....this is 2021 reboxing of a 2011 tooling, so maybe it's getting old???
  • A lot of filling, sanding and shaping around the 'chin' to get it to fit properly. Looks ok now. Fortunately the worst will not be seen given it's position under the nose.
  • Primed and then painted the internals in zinc chromate....a bit of discussion online about what colour should be used and this was a common suggestion, so I used that. Apologies in advance if it's not the right colour but so little will be seen once the pilot is in place and it's buttoned up.
My superior half is out for the morning, so I'm hoping to get the pilot finished this morning.
ACW as usual.
ATB
The misshapen 'chin'.....and some chunky sprue gates
You can see the mould it looking a bit the worse for wear now......but thinking about it, this probably dates back to only a few years after Airfix started to up their game and so still had some way to go.
Key parts off the sprue and ready for primer and internal paint.
You can see where I'm working on filling the nasty gaps......
Filling the 'chin' gaps using Mr Surfacer 1000.
Someone years ago put me onto Mr Surfacer for dealing with gaps. As you can see I masked very closely to the 'trench' I was dealing with and then over time painted on multiple layers.
I always to do much, to make sure I have dealt with it properly and then sand back - Mr Surfacer sands back very well indeed.
First time around it didn't quite work due to a lip, as you can see. So I had to go back and touch it up.....looking back at the picture not perfect but I will see how bad it looks under primer....plus it's on the underside.
Fortunately for me, all the plans I have of the P-40Bs show that the underside of the chin was completely smooth, so no panel lines to worry about.
Green internal paint done....as I said very little will be seen once the pilot is in.
Looking good Andrew. I really like the shape of the P-40. Maybe I should try one.
Coming along nicely Andrew 👍
Geoff.
Andrew,
Looking good mate.
Thanks as always chaps for the support! Glad you approve of the progress.
Since I took the above, it's been put together.....and filled....and primed....and sanded back to address issues.....and refilled in places.....ahead of what will hopefully be the final sanding and primer coat!
@colin m - it's not a bad looking aircraft is it. I'm not sure what the best 1/72 kit is out there (there may be better than this) but the new tool (2025ish) Eduard P-40s are getting very good reviews, if you want to work on something larger.....I have one in the stash and it looks outstanding on the sprue. I seem to recall reading that 1/48 Airfix ones are not the best but I may have got that wrong.
ATB
Good progress. Definitely not up to the more modern Airfix offerings. Looks like the fill under the nose has come out neatly.
Thanks Jim. As you say not up to the newest but as a 2011 tooling I'm that surprised.
OK chaps...so don't worry, I have been plodding on with this just had not chance to upload any pics!
So a brief summary:
  • Turns out that the Mr Blobby pilot is both very flat bodied and short.....very short
  • The bottom half of the wing needs a lot of force to hold it in place whilst the glue dries...too much to do by hand....and I had forgotten that the perfect clamps buried in a cupboard.....end result a nice wing root bump I knew wasn't right but needed see how bad under primer before having another go at it!
  • Cockpit is on the sparse side....not even a gunsight - didn't bother scratching one, as at this scale and at a normal viewing distance it won't be seen.
  • I have lost count the number of times I have knocked the moulded on guns (I had been warned by someone)....more than once knocking them off completely.....in one case I given up hope of finding one that had disappeared and found it on the floor three days later...but I have JUST discovered it's disappeared again. 😭😭
  • Usual black base, followed up with usual mottling.
  • Topside Vallejo Model Air No. 41 Dark Olive Drab (71.316). Underneath, Vallejo Model Colour Neutral Grey (70.992)
  • Decals applied
  • Flory wash has also been applied but just not had a chance to wipe it off yet.
All comments welcome as usual!
ATB
Sparse cockpit and pilot....the very short and flat Mr Blobby....there really is only so much one can do with such a bad mould.....
First primer coat to see just how bad the wing root and 'chin' were....it was bad...I knew it would be but had to check...
Fix and second attempt, still not perfect but I was loosing the will.....just squint at it to put it out of focus.🥺
Mottling and top coat....
As the planes had not been on the island that long, and the US was not at war, I reasoned (rightly or wrongly) that they would be kept well maintained, so kept the mottling reasonably subtle.
Decals on.....
