Airfix 1/72 Hawker Hurricane Mk.1
flyjoe180
Joe
Joe
Earth
I've had this kit for a long while. It's a kit that has been built on this forum many times, most notably recently by Tony @yakface so I haven't gone too much into the construction of it.
Doing a little bit of reading about 85 Squadron in France, I discovered that the 85 Squadron hexagon actually had a purpose beyond being a squadron emblem. If the hexagon points were up then it was an aircraft of A Flight; if they were horizontal then B Flight.
Fighter Squadron by Andrew Brookes is a good reference for a history of 85 Squadron during the Second World War.
Once the cockpit is completed, construction happens quickly. Some filler was required around the fuselage seam and under the nose where the cowling meets the wing section. Careful masking and sanding preserves the rivet detail.
I have sprayed the dark green where the canopy will cover part of the fuselage.
And before too long the Hurricane has its familiar shape. Just the antenna and pitot tube to go on, then I can get into the painting. The wheel wells and landing gear components have been painted aluminium.
This is a very enjoyable little build so far.
That's looking great so far Joe 👌
Thanks Steven. I do like a Hurricane.
Classic aircraft Joe. Chair pulled up for this one as always.
Cheers Steve. Needed something to balance out my Stukas :)
Apart from the piping in the wheel well, which needs a bit of force to fit, this kit practically falls together!
Thanks Chris. Yeah, that bit in the wheel well was indeed a tight fit. If that's the worst that happens then this is a gem from Airfix.
Fantastic work joe , its a beautiful kit that builds really quickly and easily (apart from the aforementioned pipe in the wheel well ) and always looks brilliant when done. Ive only got one more in the stash to do !
Cheers Tony, it is a fun and easy build so far
Very nice work so far Joe
Cheers Ian
I masked the landing gear wells off with the wheels-up parts sealed with some masking putty.
Then applied reverse colours, so I can later apply the black final coat on the white base, and vice-versa, making sure to remember the gear doors which I usually forget. Good use of the left over paint I was using on the other build.
Oh I remember this. It was definitely a start back to the modelling, so I'm looking forward to seeing it finished properly.
Nice work joe , looking forward to the top colours , cheers tony
Good progress Joe.
BRILLIANT work
chrisb
Very nice Joe
Thanks guys. The kit is pretty much building itself, but I will admit that underside white/black was a bit of a pest to get masked up. I have a minor touch up to do on the white at the at the tail area, for some reason the black leapt the ridge, but no bleed anywhere else 🧐
