USS Buckley 1/700 Pitroad kit
Most EXCELLENT subject.I built the Buckley twice, Revell and Trumpeter. I saw the movie in the very early '60s, The Enemy Below. Excellent movie. Will be watching. heres a couple pics-first is Revell second is Trumpeter.
Completely missed this Richard, sorry about that. Up to your usual planning and execution I see 👍.
As to films, Das Boot and Cruel Sea are the gold standards for sub warfare to me. The stress (and boredom on Compass Rose) are palpable.
Not seen the Enigma one, and won’t. I thought it was insulting if I’m honest. Remember this film. It isn’t bad for its time.
Above us the waves is pretty good as well.
Not seen Greyhound, but it seems a bit like a reskinning of Cruel Sea so will only watch it if there’s nothing else on.
Honerable mention to In which we serve. More rounded, but a fine film, if only for Kathleen Harrison’s accent 😄
SORRY SIR IVE MADE A MISTAKE POSTING HERE
CHRISB
View attachment 1294526View attachment 1294527
Good to have you following. Lovely builds of both kits although I prefer the lines of the Revell kit better as the bridge has the right height.
No problem Tim, good to have you here. I've watched all you have mentioned...all very notable. Greyhound is interesting and great watching for the acting but as usual the narrative is always very Hollywood. It has an Allied feel to it but as usual the lone Cavalry saves the day. Okay it was team effort to get to safety. I thought the Wolfpack would fight in calmer seas and mostly on the surface.
Wabble
Great work and so small!
Thanks Bob, strike while the irons hot and while I can still see them tiny things. Conversion on the other hull will be delicate removing the gun platforms on the deck to fit the closed turrets... luckily there's no tread plate pattern. Yes I will be building both ships... no sense in leaving the other in the box.
Wabble
Hi guys, I just laid down a layer of polyfilla roughly with a pattern of rolling waves. Let that settle and will sand the rough edges before laying a thin coat and sculpture scaled wave patterns.
Here is what it looks like hardened with the dry fitted boat.
Wabble
Looking good. Interesting to see you using Polyfilla. Do you just mix it with water or do you add PVA? Does it crack as it dries?
Thanks Jim, apologese...just looked at the packaging, it's Xtraseal Puttyfiller pre mixed in a tub. Nothing else added, and it didn't crack due to the fact it wasn't watery.
Wabble
Hi Guys,
While John R works his magic in wood, I do mine with paper. Prior to shoring up the sides with thick card I sanded the waves to give it a slightly smoother roll and to underscale the swishes I made with the flat tool. The I coated the dinks and dents on the sides of the old compressed form board I used so the card will lay flat and even when glued on. I also cut out the section where the boat fits using the flat piece of the hull bottom as a template.
I glued the card with Uhu leaving the right ends to jutt out and later cut at the joint. This leaves a neat edge without the need for putty or cleaning up.
I sliced off the top following the waves. This will definitely need puttying and final sanding to hide the joint.
The view from the side shows the wave pattern, it is now a difficult decision to either add the smaller wave pattern on the surface or leave it as ius. There are two ways to do this, one is to wet the surface and and press in the detail with a rounded tip tool or use a round burr and bouncing the detail with a motor tool.
Either way is doable, just the choice of which is easier.
That's it for now.
Wabble
Looks good Richard
I'll second that!!
Thank you Joe and Bob,
I like this part of the process as it sets up the presentation for the display. The finish would give a sense of seriousness to modeling.
Here are two angles of the hull in place. It looks a little heavy in the water and may need a layer under the keel so I can show a little of the boot and red hull bottom in the areas of the wave dip. Hopefully showing some speed. The wakes and froth will be added later in the latter stages.
Thanks for looking in guys.
Wabble
