21st century toys Macchi mc205 Veltro 1/32
Tony. 1:32. You'll never get it finished. The temptation to add more, then a bit more detail will be never ending. I think for your own sake, and sanity, we need to set clear boundaries here. Having said that, the pilot looks amazing.
Another build that has slipped under my radar Tony. Just catching up with this one. Great work so far.
Well its been a very slow build so far , just havent been able to get in the shed much lately . Managed a few hours today though . The pilot has been finished and the cockpit and instrument panel painted . I havent added anything to the cockpit except a throttle lever as virtually none of it will be seen once guiseppe is installed. The control column was slid into his hand and was stuck to the floor when he was fitted ( looks like hes on a pogo stick for now though ) The issue of the harness has been sorted by making two shoulder belts from wine foil and a small chain coming up between his legs . Theres two more belts to add but this must be done after the pit is installed in the fuselage as they connect to the armoured headrest. Next up is installing the pit , then the fuselage can go together ( screwdriver at the ready !) IMG_8695.webpIMG_8694.webpIMG_8693.webpIMG_8696.webpIMG_8697.webpIMG_8698.webpIMG_8257.webp
Which still begs the question, why did the Italians have a chain in the harness?
Answers in one of my many RA aircraft books? Sadly not that I can find
Coming along nicely Tony. The chain is certainly a strong method of securing a five-point harness. Those crotch straps can become uncomfortable at times, but I suppose the flight time of a fighter sortie wasn't long.
Little bit more done to this yesterday , its stalled a bit due to me being on holiday and other things . Anyways the pilot is in place and after fitting the two belts that locate onto the headrest he has received a head ! . The fuselage has been glued / screwed together and just needs a bit of attention to the seams . The plastic on this kit is really weird , normal styrene glues not having much effect on it ( probably due to it being intended as a clip / screwed jobbie ) so virtually all the gluing has had to be CA . The lower wing is now on too and I can start looking at sorting the wheel wells - the kit ones are very simplified and basic . IMG_8699.webpIMG_8700.webpIMG_8702.webpIMG_8703.webpIMG_8704.webpIMG_8712.webp
Yup, nice. I do like the pilot's face
I wonder, is the plastic actually ABS rather than ordinary styrene?
Your pilot is looking superb Tony. The plastic even looks different in the photos, very shiny and hard-looking
The lower wing has now been fitted and the job of forming the wheel well covers has started . The edges and roof have been boxed in with plastic card , it still needs the corners smoothing out somehow but I’m still thinking about this . The seams and plugs over the screw holes have been fillled and sanded , the top wings not going on just yet till ive decided how I’m going to fasten the undercarriage legs. The instructions have you putting them in before the top wing goes on but this is because they're intended to be retractable - I dont want that , plus theres a bit of detail to be added and the wheel yokes to thin down a bit so the u/c legs could really do with going on last off .IMG_8795.webpIMG_8796.webpIMG_8797.webp
Been doing a bit more to the wheel wells . The front of the covers was rounded off by using some No Nails , squeezed into the front joint then smoothed off with a wet no1 finger . The pipes and access panels were then added and it looks quite reasonable . Theres a little more boxing in to be done now the wing tops are on and the screw holes to be plugged and filled / sanded . I cut a little notch where the undercarriage legs go so that I can fit them after painting , the notch can be easily filled after . IMG_8855.webpIMG_8854.webpIMG_8859.webpIMG_8860.webp
The last bit of boxing in has been done and the screw holes have been bunged and filled . The tailplanes have been fitted - after sanding off the makers mark on the underneath of the starboard one ! The navigation lights were just solid plastic so they were cut out and a couple of pieces of clear plastic superglued in after drilling a small hole and colouring these green and red . These have now been sanded back and polished . IMG_8861.webpIMG_8879.webpIMG_8881.webpIMG_8882.webpIMG_8883.webp
BTW are you still going with the RSI scheme in the kit, or looking elsewhere. Be interesting to see what the 21st Century toys transfers are like
Think I’m going with the ANR smoke ring scheme chris , the last one of these I did the decals were excellent , even the spinner spiral gave no trouble .
