Andrew's 1/48 Tamiya Panther D
adt70hk
Hi all
Ok, so slightly late to the party but here in the end.
Firstly, thanks to Paul for suggesting it. I can see there has been a lot of work started already, so I'll have to have look when I have a minute
I spotted the GB idea a week or two ago and happened to have this sitting on the table (as there was simply no room anywhere in the stash storage!! 😟)
And, yesterday, the model group I run at the church I attend, had an all day build day - so now the P40B is nearly done, I thought it would be the perfect candidate for the day. Planes are tricky because of the need to paint the cockpit before assembling the outside and major painting on the day is not possible. We started at 9 and finished about 4:30, so I got plenty done - as you will see below.
This is one of those kits that has a metal hull for some reason - not sure why they did it but it does give it a nice weight.
I have to say that so far the fit has been flawless.....absolutely flawless.....with a lot of good crisp detail - so if you fancy some mid-sized armour then you can't go wrong on this.
Obligatory sprue/destruction and progress shots below....as you'll see I made a lot of progress....for once!! 😉😂🤣
ACW as usual.
ATB
** this is the kit I won in the tombola last month, so only cost me £2.50.....😁😁😁😁
To attach the top, you get in place to slide it along the bottom from the back, engaging the clip in the attachment point.....
Is the croissant to scale? Looks a little large :ROFLMAO:
The paint scheme looks interesting
Looks to be going together very nicely Andrew 👍.
Don’t see too many Tamiya 1/48 tanks built so interesting to see what they are like.
Good choice for this GB. Not seen a kit with a metal hull before. I wonder why?
Interesting choice Andrew 👍
It looks a nice scale if you’re limited for display space.
The paint scheme looks like it will be “fun”😳
Geoff.
Nice subject - and good to see another 1/48 amour kit.
What scale was the Croissant, and was it nice?
Nice one, watching along, chair pulled up, brew on the go..... (y)
Geoff.
This looks good Andrew, I love Tamiya's use of screws and poly caps
Andrew, great looking build mate.
Thanks again chaps!
So just to clarify.....the croissant was 1:1 scale....albeit from a cheap multipack, so it filled a hole if not the tastiest in the world!!
You'll be pleased to hear that we were well provisioned when it came to the food.....after all, a lot of energy is expended when sat down modelling for 8 hours!! 😉😂🤣
@Si Benson - Hope you're well Si! We have a club member, who's done reviews for magazines, swears by these and turns them out for fun and they look really good.
@Neil @Geoffers - you're right, that scheme will be 'interesting'....but at least it's 1/48 and not my usual 1/72! 🥺
@flyjoe180 - you're right about Polycaps....they are brilliant!
@scottie3158 - thanks Scottie, will try not to let you down.
@Jim R - not sure why the metal hull but it does give it a nice weight. Modelcollect do the same with some of their 1/72 AFVs.
Thanks again for the support chaps. Much appreciated as always.
ATB
Nice build Andrew. Hopefully you will choose a nice funky camo scheme to add to it;)
Indeed but as I said before, it's at 1/48......you have seen my Jadgpanthers with a not dissimilar scheme....and that was 1/72.....now that was fun.....NOT!!! 🤣🥺
Good to get some feedback on the Croissant! 😂
Great progress on the Panther!
Darian
You're more than welcome!! To be honest I think the croissant got more interest than the Panther!! 😉😂🤣
Thanks again for the support chaps!
ATB
