I'm currently doing the panza Iv 1/16 , it has a lot of PE ,do you use a special primer for this , or will any one do , haven't really done too much PE , any help will be appreciated .
I use Mr Surfacer 1000 or sometimes I spray directly on. I only use primer if the adhesion properties are badI'm currently doing the panza Iv 1/16 , it has a lot of PE ,do you use a special primer for this , or will any one do , haven't really done too much PE , any help will be appreciated .
