How to cut very thin hollow tubing??
BattleshipBob
Bob
Cardiff
Morning all
I have got some 0.3 mm hollow tubing from John, this will act as conduit with 0.2mm copper wire inside as the electrical wiring on the Stugs
Is there a way to cut it to length without crimping the ends???
Lay it flat on a surface, gently press the sharp edge of a knife against the tubing, and use that edge to roll the tubing backward and forward over the surface. This should cut through it, but you’ll probably need to practice a bit so you’ll make the cut in one place rather than moving sideways with the blade.
Instead of cutting all the way through, you can probably snap the tubing after making a shallow cut. Again, test to see if this is actually the case :)
If neither of these works to avoid crimped edges, put a metal rod inside the tubing and then cut as I described above. The tighter the fit, the better.
Morning all
cut it with the wire inside it
many thanks all
not feeling too well this afternoon so if ok tomorrow will have a go and let you know
appreciated
bob
:thumb2:
I would combine Neil and Jakkos ideas. Put the wire inside, then cut it with a sharp blade (I use a scalpel) by rolling it. The wire inside will stop it collapsing.....another more complicated way is to fill it with solder, cut it, then melt the solder back out....
Thanks Tim, will ruin it in the morning lol
JLC razor saw every time for me - brass, copper, aluminium, plastic, no problem
The wire in the tube method worked well thanks, but trying to bend the tube in a right angle from the fender down the side of the body then another bend very, very close to the first on as it then goes to the lights on the front is proving a nightmare
might have to stick with copper or lead wire
try making a jig from blocks of styrene- give it lots of time to set firm
try putting cotton thread inside and bending it to stop it collapsing- think plumbers pipe bender
and/or annealing it?
good luck Bob:flushed:
Neil
Hi Bob.
You only needs the ends open don’t you? If so, fill the tube with copper or brass wire, push it in far enough so the ends still look hollow, then carry out the fabrication. The wire will stop the tube walls collapsing when you bend the pipe. It will work like a plumbers spring if you’ve ever used one...
thanks Neil, my brain hurts lol
Hi Tim, only one end needs to be open, the wire comes out of the conduit into the lights/horn etc, the other end of the conduit just attaches to the back of the main headlights
Hi Bob
Lots of choices.
Whatever you do, re open the tube with the point of your smallest round file tip.
Job done
Hope you feel better soon
Regards
Steve H
Hi Steve
its a very, very small hole, 2mm. Going to try various ideas till I find one for me
Thanks for asking Steve, off for another month, waiting list is 4 months plus to a see a consultant so going private as I have a health plan who will pay for it
If you use a rat tailed file to open the hole, rotate it anti clockwise. If you go clockwise it will bind......
Thats a good one, thanks Tim
Saw that Tamiya do cables, but not that small, swines :tired:
