HK Models 1/32 scale D. H. Mosquito
Hi Vaughan,
Well if it is it has been very carefully molded!!!
It is actually some of the exceptionally fine surface detail on the kit.  There was actually a very fine mold seam running down the centre of it and removing the seam had to be done with considerable care to ensure that I also did not remove this detail.  I believe it is representing something that they ran down a join where two plywood sheets butted against each other.  This detail appears in other places.
here is a close up photo that shows the detail:
The surface engraving on this kit is unrivalled, simply exquisite, as good or even better than Tamiya have achieved.
Anyway - I did not manage to finish the masking last night and will need to finish it tonight but I did manage to get the trickier masking done with various widths of Tammy tape including some of their curved tape.  I also used some shaped Maskatar masking for the curved section at the rear to get clean curves it does not show on the photo below because it is a transparent grey and all you can really see is the Tammy tape around it.
Ah...... that throws a different light on it. I can see that it's ment to be there in your close up photo. Looking forward to the final stages.
Here she is, all dressed up for a base coat of RAF Ocean Grey.
i am using AKI Air Series for the main base coats supplemented by Vallejo Model Air.  I find they spray beautifully, even better than Vallejo MA.
I spray in a series of light coats at about 20psi neat unthinned with a .4 needle.
Here she is after the first pass with the airbrush
then after the second pass
then the third pass
but it's still not finished. I have decided not preshade as you can see and just rely on post shading.  So I mixed the base colour with 25% white and thinned it about 25%. I then sprayed into the middle  of panels and along areas that would catch the sun. I spayed at about 10 psi
This is how it then looked
As you can see the colour is now well modulated but it needs one more touch to get the effect I want.  After cleaning the airbrush I mix the base colour about 25% to 75% thinner and then do a mist coat at about 30 psi to knock back the contrast and get the more subtle modulated effect I want.
As you can see below the mist coat helps blend the base colour while improving the overall effect
the process is very controllable and foolproof
Tomorrow after leaving it 24 hours to cure I will give it a very light sanding and wipe it down with a damp cloth before masking up for RAF Dark Green   I will mask it with this below
this is the part of the build I really enjoy
Looking at the pics on the big screen in the office the Ocean Grey look washed out and far too light - it really is Ocean Grey and is a darker in real life.
Looking Good.  I will have to try your approach to the black.
Coming along nicely there Barry mate. Interested to see the clever putty being used to do the camo.
RAF Green done..
the masking material is excellent it sinks into the detail and stops any bleed. Very easy to manipulate as well
here is the aircraft just before the mist coat.
the masking material does not stickView attachment 262127
 and just lifts away.
I spent just seconds removing the mask after painting
there is no bleed and it looks spot on, any imperfections you see in the photo is on the mask protecting the black sides
I will give the paint 24 hours to cure before removing most of the remaining masking material
First some pics with the masking removed except for the u/c and transparencies
i have just finished two gloss costs with Alvlad Aqua Gloss to prepare for decalling
i I will leave it to cure and start decalling tomorrow.
Below are my best friends for decals. A cup warmer and decal solutions.  Keeping the water warm helps speed up the process for which the cup warmer was a real breakthrough
Barry where do you get the Clever Putty from, how much does it cost and can you re-use it?
Hi Vaughan.  I just Googled for it and I cannot remember where I got it from.  I got two tins in all and yes it is reusable.  This is the second time I have used it.
Seen it in e-bay. Price from 4,95 right up to 7,50 per tin! Plus post!  It is also sold as a recovery aid so I am sure it can be found cheaper...
I remember when we had silly putty. I guess it got the smarts...
Looking very nice Barry.
You are going to need a bigger turn table when you start the Lancaster..... :)
It's not only the turntable that would need to be bigger Ian!!
anyway. I have got decals on and I have done three coats of decal softener. The decals went down well but did take a lot of solution to soften them.
Tomorrow we will see how they look and whether they need more treatment.
I will hopefully be able to apply a sealing gloss coat tomorrow.
Looking great so far Barry, waiting the end with anticipation.
Thanks Dave
Progress will be frustratingly slow this week as I have some evening meetings.  Soooo close to the end.  Four, maybe five more sessions should do it.
The paint looks great mate. Nice work. Really coming together well. Sure is big though.
As mentioned I have not had a lot of time to progress the Mossie this week but I have grabbed half an hour here and there to apply a pin wash and then, going over the model in small sections, remove the surplus with cotton buds dipped in white spirit.  It is important to wipe in the direction of the air flow to finish off.  I want to go over it once more but here is how it looks now.
I used the AKI panel line washes, the ones specially for black on the sides and undersides and the one for green/grey camo on top.
Tonight once I have checked it over I will do a single thin coat of matt varnish to prepare the surface for the next stage of weathering that is best with a matt or slightly matt surface.  Tomorrow I will be able to get on with some wear and chipping.  I have established what parts of the airframe are wood and what is metal to make sure I can get the appropriate treatment.
