Hi Vaughan,
Well if it is it has been very carefully molded!!!
It is actually some of the exceptionally fine surface detail on the kit. There was actually a very fine mold seam running down the centre of it and removing the seam had to be done with considerable care to ensure that I also did not remove this detail. I believe it is representing something that they ran down a join where two plywood sheets butted against each other. This detail appears in other places.
here is a close up photo that shows the detail:
The surface engraving on this kit is unrivalled, simply exquisite, as good or even better than Tamiya have achieved.
Anyway - I did not manage to finish the masking last night and will need to finish it tonight but I did manage to get the trickier masking done with various widths of Tammy tape including some of their curved tape. I also used some shaped Maskatar masking for the curved section at the rear to get clean curves it does not show on the photo below because it is a transparent grey and all you can really see is the Tammy tape around it.
