Patricks Eduard 1/48 "Good Evening Da Nang" F4-C
Nice painting, do you spray or brush painting or a mix for the interior.
I'm hoping to start my kit soon but it's a 1/72 and the pilot and copit is so small going to be hard to paint in the detail.
Nice start Patrick. I like the intake trunking, a nice feature. Hasegawa have a blank wall at the end of the intakes.
I didn't realised you had started. Great seats, that's some standard to keep up. But you'll do it.
Hi patrick , great start. The intake fit could possibly be solved by sanding some off the front edge of the lower wing section, thereby allowing the intake to move back the same distance , this would close up both gaps , unless theres something else holding it off. If not then as you say plastic card makes a good gap filler , cheers tony
Thanks Dave. I usually spray most of the cockpit parts & then add details using a brush. For example, the seats were sprayed green, and then the black added by brush.
With 1/72 it's hard to do fine detail work, but I've found a bit of drybrushing works wonders.
Thanks Tony. You're absolutely right, I've posted a thread on that very subject in the Phantom GB section :) it's not a perfect fix because if too much of the leading edge section is removed, it causes further issues in other areas, but it definitely reduces the horrendous gap on the side of the fuselage.
Fantastic seat!:eek::cool::cool:
That really pops!!:)
BTW, where did you get the peg from with the rubber jaws?o_O
Thank you! :) the pegs are from my local Poundland. They're very handy when a bit of extra grip is needed - like smooth fuselage halves.
Damn & blast! I've been working on this one today, filling and sanding etc. And then for a break I decided to make up some of the weapons... That's when I realised that I'd neglected to open up the pylon holes in the wings :mad:
And now I can't find one of the constructed pylon assemblies :mad::(
I ought to give up on making aircraft!
Wow this is looking cracking Patrick those ejectors look so awesome,
Something to be proud of there.
Coming along very nicely
Regards
Robert
Yep! Did the same with the fin aerials on mine, but I think I got away with it by careful marking out and reference to photos.
Coming along nicely mate. Hope the intake fit get's sorted. Not looking forward to that on mine.
