Rick's Airfix 1/72 Harrier GR3 - engine change & crew in
Looks good to me rick. They were also used as A/C tugs in the field
Yes, I've seen footage of them towing aircraft, i have a Flightpath airfield accessories kit that has a tow arm so I have that option to add some interest.
A bit of progress on these over the last week or so. So they are assembled for painting with the cockpit surround and canopies sprayed black then a primer coat, after that the grey followed by the green. Applying the white tack worms was a real drag, twice over! This wrap around camouflage scheme is just horrible to do, I got a bit cross eyed at times. I used foam ear plugs cut length ways for the intake masking blanks, I will try using this to replicate intake blanks on the finished model.
Now unwrapped. There was a fair bit of touch up required where the maskol didn't cover the grey - this is the first time trying the camouflage this way as I didn't fancy cutting up loads of tiny bits of masking tape for the infills.
You can see some of the add on bits, I applied a lighter shade of green to the top side of the drop tanks and also on the aircraft.
View attachment 284820 View attachment 284821 View attachment 284822
Been there done that with the tac rolls. Great work on the wrap around scheme Rick, looking very good.
looking good, i remember the wrap around scheme being a pain on the 1/48th Harrier I built a while back.
With varnish applied its time for decals, these Harriers don't have as many as Airfix's Lightning (as some of you are about to find out) but I do have to do it twice . You may notice that the under wing serials straddle the wing pylons, its best to add the pylons after the decals.
View attachment 286388 View attachment 286389
Thanks Colin. If you could compare the models side by side you might revise that accuracy comment, one of the things that bother me with these models is the fuzziness of the colour borders. Most references I see have a hard green/DSG border.
Thats a couple of very nicely turned out models you have on the go there.
Your paint scheme looks really very neat.
After thinking this through with a clearer head and sizing up both Harriers to assess the size of base required I just don't have the space available for a two ship diorama plus all the vehicles etc. So using this box frame and some polystyrene sheet I want to try and create a field hide site with slightly uneven ground. I have seen some hide sites with the Harriers taxiing from the PSP rising onto a road, this is something I want to recreate. The use of a box frame gives me the option of including a culvert/ditch and foxholes - if the RAF ever bothered with them!
More later.
View attachment 290640 View attachment 290641
