Although my issue is with a tank part, this should be applicable to all kinds of modelling, hence why I post in the general area.
I'm building an E-100 from Amusing Hobby right now and have come to a halt with the muzzle break. It's just not good enough since it's solid moulded with fake slots instead of them being actual slots.
I fully understand that it'd be more or less impossible to do with the plastic injection method used, but still...
Even if I had a 0.4 mm endmill and a rotating chuck in a vise, I doubt I'd be able to mill the slots out, so the question is - what to do?
I was thinking about jury rigging a scalpel blade to my accurate soldering station, dial in the right temperature that the plastic just melts but doesn't ooze over or burn, and just carefully hot cut/plunge the slots and hope that the spillover ends up on the inside and not the outside as I pull it out?
(the best solution would be to heat the scalpel blade, plunge it and then cool the blade so the plastic hardens, but that seems like too big of a risk to be honest.)
Apart from that I'm out of ideas...
The smallest drill I've got is a 0.6 mm and that's too big. 0.3 mm would be perfect but you can't drill the slots out either so that's pointless regardless.
I would really like to cut those slots out somehow - and I will make some tests with the jury rigged soldering station, but some of you must've come across similar issues before and I'm sure there are other working solutions out there?!
Many thanks in advance!
