After the abortive Revell 190 I am getting on with this short run kit. I have had both good and bad experiences with short run with Special Hobby, but in 1/32 scale some subjects are just not available unless you turn to these niche short run manufacturers.
These kits have their ‘quirks’ such as very basic engineering and no location tabs. But they can build up into excellent models.
I have some masks and will depict the aircraft with a red nose.
Not a lot of parts, not compared to most 32 scale aircraft.
Instructions look a bit crowded but taking a closer look they seem rather good and well laid out.
I have been building up sub-assemblies and adding a little extra detail.
Some very nice resin exhausts. I wondered at first how to cut off the block without breaking or damaging the parts but then I realised I did not have to!!
I really could not understand this page of the instructions at all. I can see there are alternative decals but why complicate it so much? I just cemented the transparencies into the holes, the applied the decals from underneath, made sure they had the right orientation, job done. Simple.
Here is how far I have got so far.
I have to say that I am enjoying this build. The plastic is nice and crisply molded. There is a little flash but it’s nowhere near as bad as Revell. The fit is not bad a all so far and I like the engineering. I am sure this kit will throw up a real challenge or two ahead but so far so good.
