cutting brass rod
Tom Rigg
Member
As the title says.
What's the best way to cut thin (0.2 - 0.9mm) brass rod?
I thinking a cutting disc in my whizzy thing would leave the best finish on the cut.
TIA
Tom
I would use a hacksaw and mitre box to ensure a straight cut but a cutting disc would work - wear eye protection.
At that size I would simply use a pair of side cutters (what electricians use to cut cable / flex) unless its tube you are refering to.
Roll it under a Stanley knife blade.
Side cutters or the cutting section of pliers.
Some pliers have small rotating jaws built into the hub or hinge part of pliers; I'm sure an engineer can give us the correct term
A junior hacksaw, in which case a small vice would be useful.
Whatever you use you will have to beburr or tidy up the cut ends
