Wingnut wings 1/32 Sopwith Dolphin by "Bertie" tally Ho
Robert1968
Well I know Ian's normally the one to put things in there rightful place but I thought I had better make a proper show of it and start my own thread on this.
As I stated in other thread I have made a start on this with the cockpit and the minimal rigging that really won't be seen all that much once the whole thing is put together.
I have also made a start on the HIspano Suiza V8 Hisso engine ( basic construction ) now comes the hard part of painting and derailing the engine up to give it a lifelike appearance.
Now correct me if I'm wrong here but I'm sure I read somewhere that this same engine powered the SE5a??
I have sprayed the engine black for shadow effect( also as a primer) effect before I tackle the full engine paint scheme then it comes to weathering.
Pictures below
View attachment 308877View attachment 308878View attachment 308878View attachment 308879View attachment 308880View attachment 308882View attachment 308883View attachment 308884View attachment 308885View attachment 308886
Build one Wingnut Wings is on my wish list...so I will be near just watching!!
Hi Robert
I have seen a few completed Wingnut Wings kits and reviews say they are sublime but I have never followed one being built so I look forward to seeing this progress.
The instruction booklet itself must have cost a bomb to produce...watching closely, Robert.
Hi guys I been off a couple of days and managed to get some more done on the Dolphin.
I'm following the instructions page by page so not jumping ahead just so I don't screw it up.
I really am enjoying this build and the instructions and painting guide are very good indeed.
I have quite a few individual sub builds at the moment but painting as you go has somewhat got its challenges. The Vickers guns come in 2 parts with the barrels having PE ( yet to finish ) but the detail is amazing on them.
The Cockpit facia I found quite challenging but picked out detail as and where I needed.
The decals are superb ( cartograph) and detail is very good at this scale.
I have painted up the Hisso" 200hp engine. I still have some wiring to do and a final weathering.
Internal sidewalls have a few pin marks but on closure they are all out of view. Following the guides I have sprayed the internal parts.
Pics of progress ( Sorry if pics a bit blurry
Thanks for looking
Robert
View attachment 309055View attachment 309056View attachment 309057View attachment 309058View attachment 309059View attachment 309060View attachment 309061View attachment 309064View attachment 309067View attachment 309070View attachment 309071View attachment 309072View attachment 309058
Well I was just ticking along thinking oh what's the next step in this build and then I viewed a couple of you tube vids ( oh how I have missed masking..................
WW1 planes are made up of ribs with stretched material over them. This material was not that thick even with dope painted over it ( keep the planes light and agile.
I have to mask in beteween each rib and will later spray XF63 with a dab of black to give the shadow look
Lucky for me I only have 4 wings and a undersurface of the tail to mask eh?? Oh and the airlons x4
Good job I got plenty of tamiya tape eh.
Pics up to now
Thanks for looking
View attachment 309088View attachment 309089View attachment 309090View attachment 309091View attachment 309092View attachment 309093View attachment 309095View attachment 309096View attachment 309099View attachment 309100View attachment 309101View attachment 309102
Hi Robert
Those instructions do look nice - very well thought out. Good progress :thumb2: Looks as if the work to date is all the fiddly stuff.
Great stuff Robert. I've got the Bristol for the group build - I can't believe how heavy the box is.
I didn’t know there was a group build. I build for myself and like to share my modest attempts at my skills.
Regards
Robert
Update
Well I masked off the wings so I could retain some rib detail ( guess what ( silly me masked the top surface of the wings duh!! So it took me 4 hours instead of 2.
I sprayed with xf69 NATO black
Removing the masking I think looks not too bad and once sprayed with Irish linin ( dope the ribs should show though nicely ( I may tidy up before the final coats as don't want to be too dark on the ribbing.
I had assembled al the interior cockpit sub assemblies and now the fixing of the two Vickers MG
They gave some nice additional PE detail like the cocking handles ( once spayed with primer they were attacked to each gun then finally painted with X-10 and lightly scuffed.
Attaching this mount of Vickers to the instrument panel was relatively easy as WNW have guiding pegs that you can't get wrong( I did ) alignment of the Vickers onto the frame takes a lot of patience as they have to be spot on. The instrument panel then slots into the cockpit frame and this was a tight fit and no glue was rewired as two pegs align correctly into the panel ( no room for errors
Next goes in the Engine. Again a tight fit but once in very secure
There are two mounting grooves under the oil sump that align with the fuselage cage making it all snap into place.
I have taped the two fuselage sides together so the cockpit, Engine etc all sit correctly while the parts that have been glued have time to set in the correct orientation.
I have also for later got myself some extras for the rigging.
I realised from many pics that the wing struts have turnbuckles. WNW say these are not important but I feel at this scale it wil make al the differance.
This will be a long session making up over 100
Pics of the progress
Thanks for looking
View attachment 309545View attachment 309546View attachment 309547View attachment 309548View attachment 309549View attachment 309551View attachment 309554View attachment 309555View attachment 309557
Great work robert , the cockpit looks beautiful, cheers tony
