My Little Harry Tate completed build blog
Thanks Colin, Joe, John and Steve,
You'll be surprised at how much can be hidden in 1/72 without super detailing. For the holes I referenced from images off the internet and from Wingnut instruction sheet borrowed from a friend. CA was removed with a sharp blade, first cutting around the strut and then chipping with a chisel motion. The CA will lift off because of the paint. Then I repaint any base paint that has been chipped off and blasting matt varnish over the affected area with the airbrush. Actually a swipe with a paint brush loaded with matt varnish will do the trick too.
Kindly close your mouths for the next set of images as flies are prevalent in these parts.:smiling6:
I warned you...some decapitation of Preiser figures were made to achieve the pose and look of WW1 British pilots and a civillian photographer from a Preiser Luftwaffe set.
View attachment 310308View attachment 310309
Initial putty application. This had to be worked in sections or as the amount of putty I had mixed.
View attachment 310310View attachment 310311
Slowly it's teased and blended onto the plastic figure creating folds and cuts.
View attachment 310312View attachment 310313
Stippling was done for the sheeps wool collar of the flight suite. Goggles are from plastic rod...
View attachment 310314View attachment 310315
Suitable arms were found for the officer and his cap remodelled to represent the stiffer higher British version.
View attachment 310316View attachment 310317View attachment 310318View attachment 310319
I gave them pipes made from rod and plastic strip.
View attachment 310320View attachment 310321
Putty for the long coat was teased and wrapped over the figure. The collars were added separately. Sleeves as well.
View attachment 310322View attachment 310323
My high tech tool I used for this purpose. :tongue-out3:
View attachment 310324View attachment 310325
With a little blob of putty for a cap badge applied it was time for priming.
Thanks Steve, they were my second venture into Preiser figures after the Helldiver dio. Really nice plastic to work with and lots of optional limbs to work with.
Very nice rigging and base work Richard.:thumb2:
Great looking mods on the figures, like Steve interested to see them painted-up.
Fantastic work on the figures Richard, not to mention the build itself. Looking forward to more updates now I've caught up.
Hi Richard
Always been just so impressed with each and every step of this build. You are one very skilled modeller.
Richard.
I agree with Jim, some thing we can all hope to be.
John.
Thanks guys, Fernando, Ian, Jim and John and without further ado the painting begins...
They had to be blackened first with primer and some highlights.
First base layer of paints on. Working this way helps in defining areas to concentrate on as I progress.
My first foray with Vallejo gave me a shock as some of the colours dried gloss...later on I tackled that problem.
Bit by bit I worked on the highlights and tones of the individual parts starting with the flesh tones... then working the leather jacket and boots and finally the uniform.
View attachment 310901View attachment 310902View attachment 310903View attachment 310904
A blast of matt varnish took care of the shine as well as some of the colour shades under the lighting but later you will see that it turns out ok.
View attachment 310905View attachment 310906View attachment 310907View attachment 310908
Next will be the observer/gunner...
Hi,
The camera construction was very enjoyable. at first I had to refer to references from the internet about cameras during that era. Interestingly professional photographers nowadays still use the bellows for large print photography except the plates have been replaced with digital cartridges.
View attachment 311283View attachment 311284These were good enough to work from.
Above was my rough sketch for a scale plan and below were the prepared components for assembly...
View attachment 311267View attachment 311269
Putty helped with the sculpting for the bellows.
View attachment 311270View attachment 311271
Always checking against the figure for scale.
The shroud was made with flattened two part putty and attached with the help of a tooth pick and teased into shape.
I attached the assembly with blu tac hanging at an angle to let gravity do the rest as the putty cured. The angle was to create flow blown by the breeze.
View attachment 311274View attachment 311275
Primed with black and the wood parts with yellow.
View attachment 311277View attachment 311278
Brass and silver for the metallic parts were brushed on.
And finally a coat of varnish to seal it all in.
View attachment 311280View attachment 311281View attachment 311282
After the camera and figures were completed it was time to fill the base with the composition. I took a lot of pictures. This batch does not show the added rigging attaching the rudder pedals to the rudder.
View attachment 311431View attachment 311432View attachment 311433View attachment 311434View attachment 311435View attachment 311436View attachment 311437
On this last picture I have added something to create motion. For those of you seeing this for the first time kindly guess what it is. :smiling6:
Lots more pictures coming...
Hi Richard
Absolute miniature magic. The photographer and his camera is an incredible piece of modelling.
Hi Richard
Thanks Jim, working on 1/72 scale has opened up another scale in dio making for me as space is becoming less for my displays. It's either this or switching to just figure painting.
That is just so jaw dropping Richard. Luv it a lot. The workmanship is stunning and at such a small scale. Certainly one of my favourites of yours. Well done mate
Thanks Steve, did you get to see the added detail for motion in the last picture?
Great Work Richard, The camera is just fantastic, and the flowing scarf's just top it off.
Hi Ian and Joe, great you spotted the scarves and thanbk you for the kind compliment.
