Beowulf's Gaz-66, 1/35, Eastern Express
PaulTRose
Well-known member
Tattooine
things have slowed a bit on the GMC so thought id make a start on the truck i want to do for the Military Lorry GB
GAZ-66 by Eastern Express in 1/35, kit was new tool sometime in the 1990s, and it seems even Revell borrowed the moulds and punted it out in the early 2000s so it cant be that bad
had this in the stash for a while, cant remember where i got it or how much i paid for it, got another with a ZU23 AAA gun in the back
plan is to do it out of the box, as for cargo im going to have a go at scratching something
the instructions are dire!......printed on cheap paper and stapled at one corner, in russian and english, no paint call outs or where he decals go!!.....will need to do some research lol
Paul, I have the exact same kit - doesn't look too bad although I haven't actually tried assembling it yet.
Not quite up to the quality of the Trumpeter version with ZSU23-2 that I also have lurking in the stash
WWP have their GAZ66 book at the ridiculously cheap price of £4 GAZ66
Hi Paul
I have only built one Eastern Express kit and it wasn't nearly as bad as I thought it would be. I shall watch this build with interest.
so ive had a go at making some wooden crates to go in the back
this is what one would look like in the truck bed
next step is to stain them, see which one comes out the best
A few questions I would be really keen to know the answer to, if you do not mind (I have often been eyeing Eastern Express kits, but have yet to buy one):
Was there any flash on the kit parts?
Are there many mold lines (comparing to Dragon), and are they in destructive places?
Kind regards!
no worries
no flash what so ever, not even a tiny bit, and ive not found any significant mould lines
however dont go comparing this to dragon...........dragons instructions leave a lot to be desired but this kit has absolutly the worst instructions i have ever had to use, and the kit isnt the best either but it going together slowly, next bit is trying to get the cab together
Hi Paul
I like those wooden cases. Did you make them from balsa wood or did you use a harder wood such as coffee stirrers? I ask because when I have tried using balsa the surface always goes furry and rough when I stain it.
Thanks
Thanks!
When you say the kit is not the best, why is that? Fit issues? Detail level?
Strange brittle plastic.....some parts seem quite delicate.....hard to get parts off the sprue cleanly....vague instructions.....no layout for decals or what options
Hi Paul
Thanks
Pure balsa.....picked a mixed pack of sizes from Boyes....mine havnt gone furry....must be the stain you used..causes the fibres to expand and make the 'furriness' lol
Thanks Paul
I may well have used a far too watery stain. I'll have another go as yours looks good.
Thanks! I think I will follow the build, and see how you do, if you do not mind.
Cheers!
Thanks Paul
it did!......ive found that cos i used proper balsa glue its sort of reacted where ever the stain has touched it and turned an orangey shade
since ive been asked how i made the crates heres a quick tutorial
its made of balsa, cant tell you thicknesses cos i got it in a mixed bundle from a craft shop but the edges are half the thickness of the sides
dont use pva glue as it makes the balsa curl and deform......i used UHU Hart glue which what was recommended when i bought a balsa plane (which i havnt built lol)....but it has problems since it must be 'waterproof' as it repels wood stain or acrylic paint....found it takes about 30 mins to set
first i cut sides and top/bottom...try and make them as square as possible.....this is going to be @35mm x 40mm x 60mm
glue the blocks onto the sides.......get them to the edge cos they are whats going to keep top/bottom square
add the top/bottom bits
note i didnt cut any ends,,,need measure the ends now the 'box' is together...try and get it pretty close but its dosnt have to be perfect cos the edging will cover any gaps
i used the thin balsa to cut some 4mm wide strips to make the edging
again leave the ends til last......trim to flush once stuck secure
when the end edging is added it should hide any gaps and make things neat
ive looked at modern crates and they seem to have reinforcement bits that run edge to edge, not corner to corner but i think corner to corner looks better
ive used proper wood stain on the first ones and it worked ok apart from where it touched any glue that had seeped out....went an orangey shade.....this one im going to try painting with some matt enamel just to see what happens
Nothing amiss with the crate Paul.
Thanks Paul
Jim ........ If I may join in Paul, although balsa in a very light wood and very absorbent you might find that by giving it a wipe with a damp cloth and allowing the grain to rise and then dry, you can then sand and then try a water based paint /stain again. This is a common practice in finishing shops. Though I don't know how successful it might be with balsa, but worth a try.:smiling:
John.
