“What was your first kit?” has probably been asked a number of times before, so let’s try it with a twist: show us pictures of it. I don’t mean of the first model you consider good enough to share with the wider world, but your first model at all, if you still have it (or at least pictures of it).
My very first one was this one, which I found in a box yesterday while looking for another old model to get the pilots out of for the Lightning I’m building at the moment:
It’s the Matchbox Northrop F-5A:
My father built it for me when I was 7 or 8 years old, in the early ’80s. The paint scheme is later: as you can see in the view from underneath, the decals are under it. I think I tried to copy the camouflage scheme shown on the back of the box, but for some reason I did that using Humbrol No. 1 gloss black and gloss sea blue. The canopy is cracked at the left front because I remember trying to open it to paint the pilot, but it had been glued down too well so I gave up when the crack appeared
The first kit I actually built myself was my second one, not very long after:
The Matchbox Brewster Buffalo:
This one has been painted more than once
I think I originally put the KNIL decals on, then later repainted it and used the RAF ones that I of course still had left. (Speaking of which, I think I still have some of the decals of the F-5A in my aircraft decal box as well.) Why I used khaki for half the underside when the box clearly indicated black, I have no idea. The propeller and landing gear have long since disappeared from playing with it, of course.
Finally my first armour model:
The Matchbox Panzer II:
I think I didn’t paint this at first, because the decal with the Arabic slogan on the wall is clearly visible underneath the paint, so I must have again applied leftover decals when I did decide to paint it.
