Scotties Puma AAGB
Cracking Paul, those etch parts look so much better than the kit mouldings.
Cheers Andy.
Hi Scottie
Those etch brackets looks far better. Your replacement for the one stolen by the carpet monster is excellent. It is often difficult to place PE parts correctly. The carpet monster will probably return the pinged off piece now he has had a good chuckle watching you crawl about on the floor and then waste an hour scratching a replacement :rolling:
Jim, Thanks mate luckily It was basically just flat pieces that needed putting together. I could hear him chuckling and I will probably find it when I am not looking for it.
HI Jim what you said is very very true poor Scottie as ive found out but most of my lost bits to the carpet monster is usaually nicked off him by mr hover pushed by SWMBO :smiling:
CHRIS
Chris, your right the hoover will probably get it oh the joys of moggling.
Work continued on the hull. I removed the thick featureless offerings from the hull, I should have done this before I started work on the drive train and suspension.
These were replaced with etch offerings which look a lot better.
All the linkages and springs were added. The detail is not good but as most will not be visible when finished and will be dirted up.
I had to remove one of the etch brackets as it was slightly out of position and unfortunately it pinged off never to be found so I scratched one out of pieces of styrene and as I said it will get dirted up.
cheers
Scottie
very neatly executed... love it..
Annoying when bits go flying to infinity and beyond but scratched replacement looks good - just missing the corner infill pieces at the top corner of each side (bottom in the upside down photo)
Great work. I don't know if it's a scale thing or what, but those drive shafts looks tiny, for moving such a beast along. OK, there's a few, sharing the load I suppose.
Replacing the kit part PE replacement with a scratch built replacement. Lifes a beatch mate LOL
Thanks Greg, glad it meets with your approaval.
thanks Simon I will have another look and put it right.
Hi Colin, your right they do look a bit thin but as you say they all take the strain. Jakko has posted a useful pic showing them.
They weren’t all that thick on the real vehicle:
Cheers Jakko I don't know if it's the way I search but I never manage to find pictures like that lol.
Steve, LMAO I couldn't agree more mate.
I have fitted the top half of the hull to the bottom half and added the rear inserts. The fit was very good and took the minimum of filler.
While this was set to one side to dry I made a start on the replacement engine deck. The shape was cut out along with the holes for the etch grill assemblies. I have left it a touch big so I can sand it to blend with the hull when it is glued in place.
The etch grills were not the easiest things to put together but it does come with a little jig to help. When they had been fitted They were edged with evergreen.
Next job is to add hinges, handles bolts etc.
Scottie
I’m now wondering what I searched for to get that photo … let’s see if it’s in my browser’s history. Ah, very simple: SdKfz 234 suspension. Asking Google for that turned up this photo:
And when I clicked on it, the related images section had the rear view.
You really grilled those grills Scottie.:thumb2:
Very neat work on the grills, a very big improvement over the kit part.:thumb2:
Nice work Paul, think those etch brkts look a sod to do,but they do look the part .
Gorillas look :thumb2:
Simon, you lost me with that one, is a gorilla look good or bad? lol
Thanks Graeme I like to think so.
John they were a pain but I think they look beter.
Coming along nicely paul
Ian thanks fella.
Spent the morning making some hinges from pewter, copper wire and punched rivets hopefully they look the part.
I have just noticed I have knocked a rivet off of one of the hinges.
cheers
Scottie
