SO Jim they are small tubes then which fit on the end of your super glue an the chapest C/A ive seen now for 50grams bottle is at screwfix for £1.99Something different. £4.46 from eBay - manufactured in China but a UK supplier. For applying CA glue very precisely - saw it somewhere. Disposable as so cheap.
If they don't work I'll have a go at curing the wife's ear ache :tongue-out3:
Jim, if you can undo part of the coiled wire and snip off the sharp end, they make good antennae. I had a number of these stuck into me once...didn't feel a thing. You'll be surprised where the needle goes to cure ear aches. :smiling2:Something different. £4.46 from eBay - manufactured in China but a UK supplier. For applying CA glue very precisely - saw it somewhere. Disposable as so cheap.
hi,John whats in the bottles and whats it forPercy here. :nerd:
Yesterday the 9 seeds turned up , slightly different sub species, but will be ok, the good thing is they can grow out side or in the cold greenhouse. Off to soak the seed before lunch.
also yesterday arrived the .
2.5 ltr of the above.
Balsa dowel should be tomorrow or Saturday.
All happening here at Race Towers Gardening Dept.
Hi Monica, it's Glycerine, you use it mixed with warm water and soak leaves or flowers in it. The Glycerine and water soak into the plant and after it's removed from the mix and dried it will remain soft , and not go hard and break up .HSHhi,John whats in the bottles and whats it for
thank you John,never new that,I did read once that using antifreeze or boil was meant to work as well,with much alike,must wright this down,Hi Monica, it's Glycerine, you use it mixed with warm water and soak leaves or flowers in it. The Glycerine and water soak into the plant and after it's removed from the mix and dried it will remain soft , and not go hard and break up .HSH
Monica, some helpful videos on U Tube and the net regarding the mix and exactly how to do it .thank you John,never new that,I did read once that using antifreeze or boil was meant to work as well,with much alike,must wright this down,:smiling:
