Keep going, getting even more impressed.
Mike.
Mike.
Since we’ve been getting into M60-series details here anyway, I see a need to point out that the standard M60 (“A0”) did not use the same turret as the M48I love your Magach Richard- looks to be an early one, with the M48 turret
It’s simply a different design using different kind of clampsThe US M60A3 barrel has a smooth thermal shroud either side of the fume extractor. The IDF have a clamped thermal cover, probably as their Magachs were converted A1s, which had no thermal shroud.
I thought the 105mm in the early M60s was based on the L7A1 anyway? :thinking: I realise that the Israelis constantly upgraded their original M60s though, so they would probably be very much akin to the Philosopher’s Axe eventually- look at the Magach 7s!It’s simply a different design using different kind of clamps :smiling3: You could also have sanded the American thermal shroud off to leave a bare barrel, or even modify it to represent a British L7A1 barrel (with or without a shroud), because the Israelis also put those into M60s. Though I’m now wondering if that was just the barrel or the entire gun, since the breech end is quite different too. Not that you would see that difference on a model with all hatches closed, of course :smiling3:
