Hi, I actually found these items quite usefull...
Initially I found this cutter not as acurate as I wanted for thick single cuts because of how the blade slices but it has helped with my latest 1/700 repetetive cuts of harbour supports. Perhaps I'm lucky as the cutting matt for mine sits slightly proud of the steel frame so the alighning plates function.
No problem with this with no paint creeping. I either cover the other appertures with masking tape or cut the individual circles out to make single templates for easier handling. Used as a scribing template for smaller circles as well.
The Olafs been handy with large circles used the way
Simon described if you don't expect immediate cuts.
Now these are items that I have used once or not used in a while and perhaps not at all...
I still use a tooth pick or a brush to pick up paint or stir...
Specially bought to cut rigging for my USS Constipation and has since been put aside like the Frigate.
Used only once to melt some polysterene and battery powering my little Corsair but never used as intended for since I don't solder often.
Doesn't work as well on plastic as it does cleaning metal but now since I'm starting on PE for my ships perhaps I might see use for it to clean and roughen the PE to take paint.
