This will probably only be of interest to any other poor saps like me, who still just use a brush to paint their models.
It won't be a step by step build of this bomber because Andy (Paintguy) is making the same model in 'Aircraft under construction'
What follows is my way of approaching the subject of brush painting the aircraft. Of course there are loads of others, but I'm happy with the results I obtain, and whilst it won't be an 'in depth' exercise, I hope it will (A) help brush users keep the faith and (B) Pass on a few tips and tricks that might be of some use to folks.
I give you all fair warning, some of my writings might lift eyes to the heavens.
Let's make a start......
The brushes.
I buy the cheapest possible that do a good job, usually 6 various sizes on a card for around a fiver. Flat headed for large areas and pointed ones for detailed work.
Here's the three brushes I used for this aircraft. They look a bit ropey, but they work just fine.
PAINTING
The paints I've used throughout are Vallejo Model Colour acrylics, slightly thinned with tap water ( I don't know about ratios, I just adjust the thickness 'till the paint spreads nicely) I don't use 'posh' acrylic thinners, tap water works just fine.
A couple of 'myths' to get cleared up.
First. An airbrush produces a better finish than a paint brush. Wrong. It is possible to get as good, and sometimes better surface finish to a model than can obtained with an air brush. As a bonus, a brush can do things an a.b. can only dream of!
Take a look at a close up of airbrushing on a model. Minute dimples can sometimes be seen. Brush painting doesn't have that problem, and the risk of silvering under the decals is greatly reduced.
Secondly, masking tapes etc. are a must when painting a model. No, they are not. When brush painting, masking tape, cockpit maskings, bits of sponge, play dough, other unmentionables stuffed into every orifice, paint booths, ducting hanging out of open windows are not required....sorry I digress.
....but I'm not getting into any arguments. I know what my eyes show me.
The main stumbling block with brush painting is the initial coverage. There is no doubt it's bl***y awful! It's at this early stage that folks give up. Don't! Here's why....
Here's a test card I've done for this exercise. I have used two extremes of shade....Max. light to Max. Dark, and no primer.
See how the first coat hardly covers?
This is the stage where things can go wrong. Never be tempted to thicken your paints. Keep each coat the same consistency as the first.
The picture shows just four coats. If a grey primer was used I could get the same result with just two coats, but as I've wrote, I have used extreme shade differences.
Make sure each coat is perfectly dry before applying subsequent ones. If you don't, you will streak the paint and ruin the surface.
Right Nurse, bring in the patient!
Cheers.
Ron
The brushes.
PAINTING
Cheers.
Ron
