SimonT - 1/72 PST ZIS-5-BZ Fuel Truck
Simon
That is:
a) very nice work and well rescued on the dodgy tank
b) very quick!
Well done indeed so far and keep up the good work.
ATB
Simon. Just the job
1586952025200.png a snip at £ 9950.:cool: With LPG price around half of petrol, its like increasing MPG to a more respectable 12MPG!!!!!!
Cheers Steve - you never know, I may be starting to get the hang of this painting lark. Quite enjoying myself :smiling3:
Andrew - thanks. Surprised myself with how fast it all came together
John - it would be cool to be able to afford to buy, and run, some of this kit that they sell. Imagine going down the shops in a BRDM-2
Thanks Graeme
Gave it a few coats of 'green for grey green' filter which helped blend the various modulation tones together and give a more green tinge to the colour
once this dried I coated with Tamiya X22 to give a gloss shine then once that had dried it got a coat of 'brown wash for green'
so it now looks like this
left to dry overnight
most of this will then be removed today.......
You guys who manage to scratch extra details on these tiny kits are certifiably insane!
Hi Simon
This is certainly surging on - paint already. Looks good. Have you a dio idea or not?
Loving the way that this is progressing Simon:cool:,
I`ve got used to all of your scratchduggery over the years,but what`s this i`ve just read...........?!!
...........Mr.T is using MODULATION SETS :astonished:........... to coin a phrase.......... "I DON`T BELIEVE IT"
Top stuff mate,i like it a lot!!
Andy
Dave / John - very probably
Jim - I do but am waiting on other bits ordered off t’interweb
Andy - worse than just modulation sets, there are filters, washes, pigments, oilbrushers, streaking brushers, water soluble pencils, chrome paint pens all in an attempt to up my finishing game
......and he has the papers to prove it. Usual great modeling. Max effort on the finishes-awaiting result. PaulE
Looking forward to seeing this once cleaned up. Nice to see you stretching your weathering boundaries. Paying off in spades on your other builds.
Ah, there is a slight problem that sees this grind to a halt, at least for now
I think I may not have left the varnish long enough - there has been a reaction and the enamel weathering wash has set solid
It is meant to clean off with odourless thinner but nothing touches it - Medea, X-20, lighter fluid don’t work either
Tamiya extra thin does but rather too well
Will have to leave it alone for a few days then try and repaint and see what happens
Bummer. Lesson learned. PaulE
Morning Mr T,
bummer About the wash problem. I use Humbrol enamel thinner for thinning and clean up with the Ak washes but can’t say I’ve ever left them on overnight :flushed:
Hope you can get it sorted !!
Hi Si
I am using the AK odourless - worked fine on the sturmtiger, could still adjust it after a couple of days
this time I seem to have created a new substance that could be used to coat drill tips it is so hard!
Can‘t strip with FPS or Dettol as it will just destroy it so a repaint is the way to go
Edit
Correction - MIG odourless not AK but since all these firms, VJ, MIG, AK seem to have Vallejo connections it is probably all the same stuff anyway
since the surface was impervious to all the thinners types I decided to re-spray so this is how it now looks
it has also had a coat of AK Ultra Matt this time rather than Tamiya so AK over AK - less chance of anything reacting
I shall leave it all to sit for a while now before tackling any further stages
with this fixed (hopefully) I have now created another problem by knocking the spray booth lid down onto the sturmtigger and damaging the crane and radio aerial:rolling: what a numpty
Not your beautiful crane!? Numpty? I assume it is negative, but meaning? The primer seems to have gone on well. PaulE
