With me being new to modelling can I ask what is the difference between plastic and resin kits and figures.
I prefer to use a knife for all but large plugs. If it’s no more than a couple of millimetres thick, you can use a knife to keep scoring the area where the plug attaches to the part until you either get through or go far enough that you can snap the plug off. (Only do that with thick parts, though — try to snap the plug off a thin part and it’s likely the part will break instead or as well.) After that you can clean these parts up by scraping with a knife. All of this avoids creating dust, which is bad for your lungs.sawing the plugs off if the biggest step, a razor saw is really hard to beat for that job, but you can carve them away with care.
Modern hard styrene kits don't use mould release.........the old soft type of plastic did and needed washing and the habit just stuck.Also with resin, wash the parts before construction - I know that goes for plastic too, to remove mould release agents
Be aware of how the parts go together as the plugs are often attached to mating surfaces
I enjoyed the new films as I expected a new "Phantom menace".........Much better than the movie …
