AN a close up shot an them radars are just bits of scrapIMG_5569.JPG balsa at the moment to show what the real radars when i build them will look like
Looks great Chris, wish I had even a little bit of your electronic know-how!
Are the brake lights on lol
HAHA Bob yea thats a good one as them white running an steamin lights are realy bright but they got to be so i can see them in daylight so i know which ship in mine if a lot of models on the water as i dont want to ram them
HI Jack yea it does help to know a little but im not that great at eletronics as some how it just flows from my fingers must be hidden sections in me ole grey matter that i dont know about till i get doin something like this then it comes out lol
chris
AN THE TOP grey section of the mast lifts out just in case its a tight fit in the car
some side veiws shots an the last two ive fitted on two three panel W/T DOORS at the bottom of the mast IMG_5572.JPG
AN now some shots of how the rear main mast is now looking but again i'll build the big rardar in the winter as ive got to work out how im gonna stick photo etch togeather but ive already worked out how its gonna go an all the thinkin about how this will be done is all in my mind so no probs till i start it an its 4 " wide quite big by my normal standards IMG_5577.JPG
an a shot OF the A/C lights on low 6v power instead of 12v which when its on the ship they will all be running on 12v D/C IMG_5579.JPG
WELL guys thats all for a while as the nxt job is gonna be a nail biter as on friday i will be then fitting in them portholes in the hulls , an the ankors hawers ' an the water intake pipes faceing backwards so if she hits any weed floating on the pond surface they wont hopefully suck it up an block up the inlets as if it does then the big ESC will overheat an burn out an maybe catch fire so to be sure it dont happen im fittin in two water inlets one on each side of the hulls
TTFN
Chris
Chris, if you don't put up the Christmas tree this year you have a substitute. :smiling3:
For you sticking the bits together also needs strength and durability as its a working model. Don't want bits falling off into the lake or pond...unretrievable.
Nice mast. :thumb2:
What are those white slim bulb like thingies? I have two of those on top of my main rear mast to add.
Chris, if you don't put up the Christmas tree this year you have a :smiling3:
Nice mast. :thumb2:
HI Richard m8 yea a substitute. xmas tree be a bit on the small side though :smiling: an yes i dont want bits dropping off the mast thats why i built it usein 2mm brass box section so i could stick my brass rod with all the sencer pods on into the box section then will be very strong an the white slim bulb like thingies are sencor pods that scan for eletronic signals through the eletronic spectrum i think as most warships masts are normaly covered in them hope that has anwered your question Richard an i hope you are feeling better an cheers for having a looksee at what im up to as i think your spy ship in the size you are building is out of this world
chris
Just had a good catch up with this build Chris and I have to say it is stunning work that you are doing :smiling3:.
Everything about it is pure quality and I would really like to see your work in the flesh and also to see them sailing.
Looking fabulous Chris. And, I know that this is only a very small part of this marvellous working model.
Paul
