Hi all
So you may remember I recently purchased a coat of Future in it's current incarnation (can't remember what it's current branding is).
I'm not far off giving it go and so have been doing some research but as usual there are a range of opinions on how it should be used through an AB and so I'd welcome your collective wisdom on the topic:
Please let me know how you use it and any tips you may have.
Thanks as always.
- Thinning - most people seem to use it straight from the bottle but I have seen some people thin it with IPA (by about 30% for 70% IPA) or even water.
- Cleaning - most people seem to use cellulose cleaner (i have none) but some also use IPA (I have some 99% in the cupboard)
- Needle size - one person recommended a larger needle size e.g. 0.35-0.4mm as a small needle apparently resulted in pitting for him. I've certainly found large needle sizes better from a clogging perspective with Vallejo's varnish.
- Spraying technique - unsurprisingly much like paint i.e. thin coats so the model isn't flooded. One example I saw gave it a blast of air only from the AB so dry the coats off quickly before applying the next one.
Thanks as always.
