Just a brief update.........
Not a lot to see,but as usual...... it took a while!! :rolling:
I`ve added some peripherals and bulked out the base of the "Yoke".........
The handles are left overs from a Tamiya StuG III,the vents above the handles are made from a cut in half Stowage box which i then cut and filed down,the Yoke was framed with cut plasticard which was then filled with "Greenstuff",the pivoting lug is a cut down Rawl plug..... 8mm because the trailer base has an 8mm recess for it!!
The other parts are just cut down electrical packing items or left over bits from previous builds.It all looks a bit messy there,and here it is with primer....
These pics show the areas that required clean up.........
Several places as you can see,here it is "Full On" so to speak..........
Again,it`s a poor pic,but you get the idea,it`s now been cleaned up an had a coat of OD,i have to say i`m pleased with the outcome so far,but now i have to fit the reflector and build up the Light`s internal gubbin`s,(hence painting it OD already). :surprised:
It`s starting to look the part now..... Honest!!!
Thanks for looking in,and as always,all thoughts,hints and tips welcomed!
Andy
