1/72 HMS Victory Cross Section
Jim Apart from your modelling skill:thumb2: another impressive thing is the quality of the laser cut ply.
Quite often you see really burnt edges, this seems to have been machined with care. Good idea with the use of the solvent stain, that veneer wouldn't stand up to a lot off sanding to remove a raised grain from a water based stain.
Hi all
Thanks again for all the your encouraging, supportive comments :smiling:
A bit of progress. The next job was to complete the inside planking of the hold up to the deck supports for the orlop deck.
The last plank had to have notches cut to fit around the deck supports.
In the real ship massive riders run across the hold which strengthen the hull.
They needed a bit of fettling to get a decent fit - and lots of clamps :tongue-out3:
Holes had to be cut in the bottom of the hold for the pumps and the base of the mast. You are supplied with templates to print off. The instructions have you mark the positions, drill 2mm holes around the edges and then join the holes with a knife to complete the holes. Sounds easy but surprisingly difficult.
The mast step was fitted and I built up the stand. Stained the hold and the stand with oak stain and test fitted the pump well.
Thanks once again.
May your jabs be painless and your masks not irritate :smiling5:
Great work Jim. Just had a quick catch up and that's coming on very nicely.
ATB.
Looking great Jim. Love the “front” and “back” labels on the template in case you forgot which side starboard indicated....
Hi all
Paul, Lee, Andrew and Tim - thanks guys :thumb2:
Finishing off the hold. The pump well was fixed in place and then the two large hold platforms were built up. Very straightforward apart from fitting into the awkward shape against the hull.
front view
rear view
The orlop deck beams were cut from their laser fret and cleaned up. As John mentioned earlier the charring from the laser cutting is not too bad but cleanup does take time. The beams were stained and checked for fit.
...and then glued in place.
That's the hold pretty much done.
Thanks again guys.
Hang on in there :tongue-out3:
This is great! I love the staining you’ve put on. It’s really adding to the scale effect.
Hi Jim,
I`d missed this one `til now:rolling:,what an interesting model!
Certainly a little "Different" from the norm,and makes for a fascinating read,top stuff Sir:cool:.
Andy
I agree with my dear friend Ron aka 570 whole heartedly.
Will be indeed worthy of the DOGS AWARD.
And there was me thinking I was your "Dear Friend" Mr. Race!!:flushed: .........
........ oh well,"It`s MY ball,(comment),,and i`m taking it home"!!:loudly-crying:
Sorry Ron..... Just couldn`t resist!!;):tears-of-joy::tears-of-joy:
Andy
Andy
Not a problem, Andy.
I'm sure Mr. Race has a couple of balls he can still play with, so the one you are taking home won't be missed! :tongue-out3:
Sorry Jim, away on a tangent there.......
Andy
Andy how can you say such a thing, you are indeed a dear friend as well. .:cold-sweat::cold-sweat::smiling3::smiling3:;):nerd:
Don't apologise for banter. In these strange times I welcome all forms of fun, jokes, banter, eccentricity and good old plain daftness. You and Ron have plenty of the latter ;):smiling2:
Yeah,sorry JIM!
My sense of humour interrupted this fine thread too Sir:rolling:....
Only meant in jest i assure you :thumb2:,
Andy
