I thought I was going to have the same problem when I painted my ju-88 but spraying in light coats with light pressure seem to work superb. Obviously a bit different with bristles. I presume you almost need the paint thicker so it doesn’t run?An unexpected problem! I used AK3 Light Green as the base for the wings & tail, and I'm going to use AK WWI German Lilac over this - When I start to brush paint the Lilac - I get 'creep' along the corrugations!
The Lilac is a bit too thin - it's neat out of the bottle - usually I'd expect to have to thin the paint, but I really need to thicken it. I think part of the problem is that the AK3 Green is too smooth - it allows the brush paint to flow too easily. After a bit of deliberation, I decided to give an overall coat of Matt varnish, to try & stop that creep - otherwise, I'll be in the round of touching up green, then lilac, then...............
David,Great job Dave coming along nicely, I always enjoy your builds from the more obscure manufacturers you know roughly whats in the box and what to expect with it rarely ever moan just crack on and tell it like it is ,almost there looking forward to the next instalment. Dave
