Airfix 1:35 Cromwell CS WIP
slupanter
Member
Hey all, started the new Airfix 1:35 Cromwell CS a few weeks ago. base painted yesterday.
Lovely to build, a real pleasure.
There is a 1:350 HMS M1 submarine there too ;)
Looks good, how does it compare to the Tamiya kit? I've been wondering about the Airfix version.
It's been a few years since I build the Tamiya kit but it would say similar in simplistic build with great detail.
I wonder if it's the Tamiya kit. Airfix don't manufacture 1/35 kits as the other tanks are re-boxed Academy kits. Welldone for Airfix doing this joint thingy as we seem to have problems getting Academy kits.
That looks like a nice Cromwell coming together, Alexander.
Hi Richard
It's actually a brand new tiling for Airfix.
One review has this to say on the subject:
This is a new tool from Airfix, the first of the armour line that is from their own CAD files, which we understand were moulded for them by Academy, their long-term partners in the new Airfix 1:35 armour line.
HTH
Hi Richard
HTH
Thanks for clearing that up Andrew. It's about time Airfix started their own 1/35 line. Good for them. I can still remember they tried reboxing Peerless kits in 1/32. I have that 17-pounder kit built. No one has done that in 1/35 as far as I know.
No problem at all. I've actually got my eye on this as I've heard very good things about it.
Alexander - it's looking very good so far. I'll be following this with interest.
ATB.
The 17-pounder is one of those things I want to build, but haven’t found the motivation to actually want to do yet :)
Not normally a 'armour' fan, but tempted by this one, as recently read a book (Troop Leader, by Bill Bellamy) which tells of his time after D-Day and has an episode related in it that may make an interesting dio.
Bronco I believe have it, I know there is an early and late 17pdr in the range to go with the Universal carriers.
Thanks Mike but Jakko's already mentioned it too. I don't regularly check websites and only rely on what the LHS stocks up. In the past with so little brands it used to be up to date or I could have missed it as lately less than a handful are normally brought in of a particular kit or pre-orders made.
Do you mean: “is the Comet a Cromwell with a 17-pounder?” (I ask because I didn’t quite understand the question :)) The answer to that is “essentially, yes.” The Comet is a development of the Cromwell with different (wider) wheels and track (plus return rollers added), a new turret with the 77-mm gun and assorted minor changes.
The 77-mm gun was a development of the 17-pounder to shorten its cartridge case so it would be easier to fit the gun inside a turret, and to handle the ammunition inside a vehicle. The projectiles were exactly the same, but the cases shorter and (off the top of my head) fatter, with less propellant. As a result, it was less powerful but that actually benefitted the weapon, it turned out. The name was changed to prevent confusion and the wrong ammo being delivered to units.
Do you mean: “is the Comet a Cromwell with a 17-pounder?” (I ask because I didn’t quite understand the question :smiling3:) The answer to that is “essentially, yes.” The Comet is a development of the Cromwell with different (wider) wheels and track (plus return rollers added), a new turret with the 77-mm gun and assorted minor changes.
Sorry, Typo. Got you, I always thought it was a straight-up 17pounder in the Comet, I didn't know it was a modified gun based on the 17pdr.
The canal jump by any chance? :smiling2:
The 17pdr was fitted to the A30 Challenger, which was a lengthened Cromwell hull, Six wheels per side instead of five! Then they re-used the name for the Challenger 1 & 2 more recently.
