Churchill AVRE Toon
Hi I started by removed all the engine deck and track guard side details
Pete.
Hi started with the turret as there not much to it.
Added tie-downs to the side, made up to to antenna masts, added a bit more detail to the barrel bore
Fitted new front, headlights, tow shackle.
Fitted engine deck and some extra detail
Added a some more detail to the sprocket adjusters
Thank you for looking in.
Pete.
Hi I've tried to improve the look of the front sprockets by added some details.
Added track access hole added 1/35 track.
Added side hull details, air intake stacks and added some extra detail, exhaust pipes plus brace,
Pete.
Looking fantastic Pete. Great detail work. The spigot mortar gives the turret a bit of a Dalek like appearance doesn’t it ;)
And the Toon Master does it again. Great skill in these models especially when they include conversion work. They also bring a smile to my face.
WIP
Hi made up the support cables and anchor point, finished making up the tracks.
Hi managed to get the hairy stick out and got the primer coat on
Thank you looking in this is now shelved lost interest .
Pete.
Hi have decided to finish this one off.
Hope you like it.
Pete.
Great finish, esp like the spare track links on the rear track guard. Pete. Scratchery as your normal high standard, those sprocket cut outs are impressive. :thumb2::thumb2::thumb2:
Whats next ?
Got to love it Pete. Brilliant work as always.
See it's marked up as 6th Guards Tank Brigade. Are they the kit decals or your choice? The only reason I ask is that happens to be the unit I mark up my wargaming Churchills for and is not one you see often.
As I said, great work.
ATB.
ATB.
Thank you, very much appreciated, half and half on the decals but the 6th GTB is a part of the Churchill Toon kit.
