OEZ 1/48 Sukhoi su7
yak face
Staff member
Sheffield
Heres a kit ive been meaning to start for years . I bought it at the Waddington airshow about 10 years ago for the princely sum of £6 and its been patiently waiting up the loft till now . Its hard to believe this aircraft first flew only ten years after the Tigercat ive just finished . Its a nice kit ,reasonably detailed , recessed panel lines and a choice of four schemes . The only thing im adding is to replace the simplified kit seat with a resin one . Hard to believe a significant aircraft like this and this tooling is the only one ever done in 1/48 ! Its since been reboxed by various makers but if you ever see a 1/48 su7 then its going to be these moulds . 99C2E157-772E-41F3-90F0-1D0999B1EF05.jpegFCFC3686-85C9-4213-BE88-797523E79A33.jpegDADCEDB3-667C-4844-9AB2-0A98A30A699B.jpeg7C032BDE-5226-4D5B-BE89-7890A599C793.jpeg7B61F4E5-9890-4D56-8D54-8BAF24454E96.jpeg6602E34F-3269-4767-A590-B53BF3D0D98F.jpegB4D97A6E-65D1-477B-A0AF-EB0730A4CFD3.jpeg
That seat is a great improvement, but judging by the photos of the sprues and parts, the kit as a whole doesn’t look all that bad.
Yes its not a bad kit at all jakko , according to scalemates it was tooled in 1989. The cockpit is quite nicely done but the seat was very simple . To say it was widely used by all the soviet bloc plus quite a few African and middle eastern airforces its amazing that theres only ever been this kit in 1/48 . Its a surprisingly large beast too .
Tony,
I remember having a go at this a long time ago! I think I had trouble withe the undercarriage, not being strong enough. Quite large - I suppose the equivalent of a F-105.............
Hi Tony, I think I have done one in an ESCI reboxed. One and only Russian plane I've built and a rare jet for me. You have your's in an earlier mold which I think is better than the worn out mold I got which made the recessed lines less crisp. Here's a finished pic of it. I have a build blog of it if you'd like to see.
Nice to see it being built and I didn't know it's the only one in 1/48.
Looks excellent richard , way to set the bar high !! Hopefully i can do as good a job on mine . I’ll be doing the nat metal soviet version too so plenty of scope for different shaded panels ! One thing you can help me with straightaway is did you put any nose weight in to stop it tail sitting , if so how much ? Cheers tony
Seeing it's Russian I suppose I should take a front seat Tony.:nerd::smiling3:
Da Dzjhon , its about as typically Russian as aircraft get - no nonsense , built like a brick kakathouse and kept in service for far longer than it deserved to be . I mean just look at the ejector seat , unique to the su 7 , it looks like a really heavy duty barbers chair !!I love it though , its just such a straight forward beast of a machine. And its just got to be in the classic cold war bare metal scheme . Cheers tony
Tony, if you're into Russian planes, take a look at this. It's a Sukhoi too but a lighter version for the future. When you say brute, I believe you as the recent SU's have been big and heavy. I've been close to one and the cockpit is nearly two stories up.:smiling6:
I started the kit with only the fuselage put together long before actually continued years later and completed it. Can't remember the tonnage I used but it was one heavy cigar shaped baton. Just took the plane out and doesn't feel that heavy now. The front undercarriage is strong so I think you can pack the lead.
Oh...something my friend from Moscow has photographed and might take your fancy...
Got the cockpit sides painted and stuck to the floor , also the front undercarriage bay which the cockpit sits on . This has given me a chance to dry fit the cockpit and see how the ejector seat fits . Well it didnt ! For a start the armrest were fouling the sides so I cut them off with the razor saw , thinned them and re attached . The seat now fits snugly between the cockpit sides BUT it didnt look right , seeming to stick up too far and the headrest looked too far forward. A quick try confirmed it was way too big to allow the canopy to fit . So my options were use the rubbish kit seat or a bit of surgery and use the kit headrest on the resin seat . So the razor saw came out again and the frankenstein seat now looks correct and more importantly the canopy fits over it! EA45C4AD-8959-4027-811E-D8F721845CB4.jpeg3E2D0EAE-FDCC-4340-A2DD-D8C877ADA93F.jpegFEED0500-60C0-4A72-B6F4-C58E269C39E9.jpeg70C055C3-3402-440A-ACE6-F58F70190CCE.jpegFC6BB54F-5E0D-4B3F-9C29-4ABDAC856A38.jpegCA37032E-B09A-4C5C-A3B4-C378D2D4D307.jpegC707A76C-B50B-43DE-810F-27B528C9BF89.jpeg211FB231-F2C7-4944-8CEC-7ECEB4BC041C.jpeg
Hi Tony
£6 - I'll bet the resin seat cost more :smiling2:
Even with the fit issues and the surgery needed the seat looks good. The kit actually looks quite nice. I've not heard of the maker before.
Hi Tony
I think it did Jim !! :smiling5: Looking at it now I reckon the seat was for a later su9 or 11 , even though it said su 7 on the packet.Maybe they just got it a bit wrong ? , the headrest just looked far too long , the poor pilot would have finished up with a humpback !
Made a start on the instrument panel too , a base of black grey then it was out with the dotting pen to do the instruments with gloss black . A few colours for the switches etc and ill give it a bit more of a tidy up and try and drybrush the dials tomorrow . D8023B43-6E92-4636-87F7-660377408A34.jpegCBAB8C88-178A-421D-919E-5AA0359BD104.jpegB19FF44B-9411-4F4E-8334-996A0100D990.jpeg
Tony, your instrument panel finish is way better than mine. I totally forgot about the ejection seat height issue. Even the original seat needed thinning at the base. The problem is compounded by the thick plastic of the clear canopy. So I had mine open. Glad you fixed the issue.
Just a little warning...the wing roots need dry fitting to determine the angle of the enhydral. Also be ready for fillers. I decided to glue the top and fill the gap on the underside.
The vertical tail stabiliser also needs a lot of filler at the joint to the fuselage unless you shape a groove to fit the contour of the fuselage.
Thanks richard , a few test fits yesterday revealed exactly these problems , i think i might glue the wing tops first the fit the bottoms after and i think i’ll sand a flat on the fuselage to sort the tail. I’ve already glued the two halves of the tail but when offered up to the fuselage the spine is a little wider, if i had known i would have put a bit of plastic card in between to widen the tail at the base. Cheers tony
