Toon Churchill Wurlitzer and Ark 1
Just started work on the next two Toon Churchill's the Wuritzer and Ark 1
Started by cleaning up the basic parts for both build's.
Then removing most of the upper hull details.
2x kit parts
Before
After(there is still more to remove)
Made up the Bangalore torpedo launch tubes from white tubbing and rod with one end round off.
Mock up
Pete.
2x kit parts
Before
Mock up
Pete.
Great work Pete your enthusiasm for these kits knows no bounds looking forward to watching this one. Dave
Cheers David, well I've built over 50 now so hopefully the enthusiasm doesn't run out just yet, just don't expect anything to clever.
Pete.
WIP on the Wuritzer & Ark1
Glued all axle pins into the road wheels, cut out 8 white discs from white card added lightening slots and hex nuts to drive sprockets to hopefully improve lack of detail
WIP on the Ark 1 Churchill​
Major surgery in progress
Stage 1. cut off rear track guards
Stage 2. cut off side track guards
Stage 3. Cut off top track guards
Stage 4. Cut off material from the turret ring base
Mock up of side track guards on
As you can see the rear sprocket has to be repositioned by raising it by 7mm
A very big thank goes to Scottie for supplying the rubber band tracks
Wow your exceeding your self on this one Pete. Some top notch scrathery.:thumb2::thumb2::thumb2::thumb2::thumb2:
Thank you John, when the Churchill came out everyone went mad I'm going to build this I'm going build that and no one built any of them, so I've taken up the challenge so I had to up my game.
WIP on the Ark1
Repositioned rear sprockets by raising them up by 7mm.
Blanked of turret ring.
Started work on on rear engine deck and air intake.
Cut tracks length and fitted.
Started work on modifying the side track guards
Up to the usual high standards I see Pete…..always fun to watch a skilled man at work!
Pete,
Loving the conversions, it takes a lot of skill and faith to remove so much plastic.
