Electric for me, and its green as well nearly 4BO
TAXI
TAXI
Tim, I store petrol in a sealed metal jerry can, doubt that any evaporation takes place bang the sealing lever and the lid pulls down airtightThe deposits are the unleaded petrol degrading Gerry. Some of the components (petrol is a relatively crude mixture of hydrocarbons) oxidise and become insoluble.
After my interest was piqued by this thread I’ve read around the subject. The advice for unleaded fuel is that its best used with an additive in garden machinery because it degrades in storage. Unleaded also absorbs moisture when stored which makes starting the engine harder and harder. Briggs and Stratton, amongst others, make an additive specifically for this purpose. The additive can extend storage times for fuel by up to three years. Without the additive storage time is limited to four to six months. This advice is repeated on several manufacturers websites
From a personal viewpoint whatever we have left at the end of the season goes into Sue’s car. forg two years ago and have half a can of petrol water than is no good to man nor beast. :loudly-crying: I will have to change my system soon though as she’s buying a diesel, so from next year I’m using an additive :surprised:
It isn’t an issue when unleaded petrol is used in cars, by the way, because the petrol is used relatively quickly.
Until they come up with an electric vehicle that will do 350 miles minimum during winter (lights and heater going) without charging (sister lives 340 miles away) or a hybrid that will do 50+mpg (why don't they do a diesel hybrid??) plus able to tow a 1+ tonne trailer, I'm going to be stuck with an ice vehicle.Electric for me, and its green as well nearly 4BO
TAXI
Thanks for the info' Tim.Not tight….sensible! Your classics are designed to run on leaded fuel. Ethanol reduces pre ignition, much like lead did. By leaving the ethanol in you are protecting your classic engines.
Have you seen this Gerry.Until they come up with an electric vehicle that will do 350 miles minimum during winter (lights and heater going) without charging (sister lives 340 miles away) or a hybrid that will do 50+mpg (why don't they do a diesel hybrid??) plus able to tow a 1+ tonne trailer, I'm going to be stuck with an ice vehicle.
Seen this movie a few years back your right its a great film, thought i was the only one who seen it lolHI 570 NO PROBS but is it on utube as this story takes some beleiveing i think this is one of your wind up post ? lol
chris
What is termed 'the light ends' may evaporate off and the two mentioned causes result in a 'gunk' forming that blocks jets and even fuel lines - much like beer lines that aren't pulled through often enough :disappointed2:! As mentioned, drain fuel tank; using kero clean filters and lines and flush through with a little fresh fuel. Oh, and check for rust particles or discolouration - this has often worked for me in the past mate!How old is the fuel in the mower Chris? Unleaded fuel is only good for about six months. After that the ethanol in the fuel absorbs too much moisture from the air to work properly.
OH John you had to ask that dint you could not resitit could you boy oh boyCan you use Fire ! :nerd:?
I WAs thinking more for use in small engined garden machines most of which are two stroke.Not sure that’s a particularly good idea Ian. Apart from the obvious safety concerns, ethanol is one of the additives used to reduce pinking in an engine so minimises damage. In addition, modern car injector control systems are designed to work with ethanol mix petrol. E10 produces about ten percent less CO2 per unit volume burned than ethanol free petrol. Removing the ethanol will cause the engine management system to work inefficiently when trying to control emissions, in turn reducing engine power and decreasing engine life.
Seems like the petrol head equivalent of the anti vax movement to me!
Will have a proper look at it tomorrow, thanksHave you seen this Gerry.
That looks a fine chassis!Have you seen this Gerry.
Saves wasting money on lawn mowers :tears-of-joy: !Can you use Fire ! :nerd:?
