Hi guys, this saturday I decided to do the damaged Japanese machine gun in the bunker. Instead of using the Nambu, I thought of saving that and build a heavy Type92 from scratch. Since it's damaged from the internal explosion it doesn't have to look too perfect. This is what it looks like pristine...
The difficult part is to to do the cooling vanes along the barrel but in
1/35 I thought I'd get away with just using wrapped wire and painting. I first dug out a hypodermic needle 21 Gauge in the green packet. The pink ones are 18 Gauge suitable for 50 cals.
Wanted to use the cut off end but the resin glue was tough so the pliers mangled it a bit. I made sure I cut off the sharp end before the procedure.
Holding the needle in a clamp vice I then wrapped three different widths of masking tape over it securing the ends with CA.
I heated some copperwire with my flamethrower just to soften and make it easier to wrap round the tape. Meanwhile I added the gas recuperator tube underneath with some spacers. After wrapping the copper wire I tacked it down with CA.
The sights looked flimsy so I made those from copper sheet. Cut the shape and bent it in three places with the help of needle nose pliers.
Secured the sight with CA. Contemplated drilling the holes on the sight guards but I don't thing anyone will notice it in the diorama.
I then added the gas recuperator tube along the base with a short length of copper wire. The reference picture above somehow doesn't show it but others have.
Looks like a pneumatic drill. :smiling6: The next thing I'll be doing is the tripod cradle and maybe part of the main rear body that should be partly hidden in the bunker.
Trying to find time to build is precious...even as I was typing this I was called to rescue a fallen pot of plant and make new wire holders to hang it from. The plastic ones don't hold heavy plants well. Hope tonight there's free time to do the rest or maybe tinker with the trees in the Malayan Emergency dio.
