Bigfoot57
- Joined
- Jun 24, 2015
- Messages
- 1,230
- Location
- Weston Super Mare
- First Name
- Colin
- Location
- Originally a small village outside of Reading Berkshire called Burghfield Common
Hello again been a few weeks since I last posted as I had to move and set up everything again which has taken up most of my time so now I can relax and restart my modelling again
So what have we got well as the title says it’s an Airfix 1/12 Bentley Blower which I know has been done to death on numerous occasions with some builders literally scrapping most of the model to scratch build more accurate parts
Mine will not be like that I will add detail where I think it makes the model look better but this will not be a rivet counters model I do not sand off nuts and bolts etc just so I can then glue on more accurate ones only to have them fall off several months later as the glue dries out and losses it’s ability to hold the part I've been there before with my DB5 build as of now it has lost at least 4 of those acorn nuts I purchased for the head cover whereas if I had left the moulded ones on they would still be there as there would be nothing to come unstuck
So with that thought in mind here are the obligatory sprue shots
I won’t bore you with the engine construction as you can see it’s very basic and will need a lot of work to make it look like and engine so where do we start
1st off spark plug leads there ain’t any so that will be my next task which after several attempts using cloth covered wire i abandoned as the cloth kept unravelling so it was pvc wire painted in matt white to simulate the old style type of wiring that would be in use at that time
Next I made some fuse / junction boxes to attach the leads from the spark plugs to the distributors this was a small piece of blockboard with holes drilled to accept the incoming & outgoing leads
View attachment 437801View attachment 437801View attachment 437802View attachment 437803
And for the end of this stage I painted various pipe work and engine parts to make a more representative look to the engine
Regards
Colin
Regards
Colin
