Junior's 3x 1/72 PSC Cromwells
Hi Andrew
Those are looking really nice. Decals always make a model 'pop'.
Hi Andrew
Andrew,
They are looking very nice indeed mate.
Jim, Scottie
Thanks for the support. Generally pleased with how they turned out and it's good to have three in one go to practice different techniques on.
And Jim, have to agree with you. They definitely bring a model to life!
Thanks for stopping by.
Evening all!
Ok so time for decals. As you know I'm not a stickler for historical accuracy but at the same time I like to try to at least be in the ball park where necessary.
As I explained in the initial post, these will be a second troop for Junior's11th Armoured Division Recce Regiment....or more accurately regiments plural......
For those not in the know, although the the 11th Armoured Division only had one Armoured Recce Regiment, as was the same in the other British armoured divisions, two regiments actually served in that role. In the run up to D-day and the next two months or so it was the 2nd Northamptonshire Yeomanry.
Unfortunately though, the 2NY took such a battering in late July/early August during operation Bluecoat, apparently mainly due to the action around Vire, that it was formally disbanded. According to the tinterweb some of the remaining 200 soldiers of the regiment went as replacements to the 1st Northants Yeomanry and some went to the 7th Armoured Division. The unit was replaced by 15th/19th Kings Royal Hussars, which served in this role until the end of the war, from what I gather.
As a result of no definitive info on the web I've had to take a bit of a liberty/guess with the markings.
Not all 11th AD Cromwells (and variants) I've found had the tactical markings on the turret side as was the 'official' practice, although C squadron 2NY appear to have done so, as do at least some B squadron vehicles allegedly from 15th/19th Kings Royal Hussars.
However, none of the Challengers that served with these units appear to have had the tactical markings on the side of the turret, and there are fair few pictures on the web. I have seen one though (unit unknown) with it on the rear of the turret, as I have seen elsewhere e.g. on some Churchills.
I also have some census markings allegedly for Cromwells (vehicles and units unknown), plus some for Challengers with plenty of pictures of these on the web.
One of these is an A Squadron Challenger apparently of the "..2nd Northamptonshire Yeomanry passing through Flers France; 17 Aug 1944." I've not worked out when 2NY were replaced by 15/19 KRH, although the answer might be waiting in a Christmas present, so it could be a 15/19 KRH one but either way it's definitely A Squadron 11 AD one.
I have therefore marked the Cromwells as A Squadron to match the Challenger and also put the tactical marking only on the back. I've used the census markings regardless of whether or not they're strictly speaking correct. The ones on the side turrets are actually 15mm ones but I don't have enough 1/72 ones.
Interestingly, the bridge weight sign proved surprisingly problematic.
I've gone with 28 on a hollow yellow circle, as one of the 11th AD Cromwells on the web has that on it, although I have also seen 26 and 30 in various forms - but never the 27 which I have seen on a number of kits and indeed some decals I have in the stash. Interestingly most pictures I've found don't show one at all.....
Anyway after all that unnecessary waffle, they are below.....for better or worse.
ACW as usual.
PS I didn't a single '28' bridge weight sign, so had to assemble it from the relevant decals......three in all..... :anguished::crying:
PPS Junior's existing Cromwell troop is from the 1st Troop, C Squadron, 2NY.
The dreaded weight decals......not quite as bad as it appears though. thankfully....
You can certainly take a bow with those Andrew, beautifully painted along with the crap on the back .:thumb2::thumb2::thumb2:
Good morning all
So the Cromwells got a satin varnish coat ahead of the weathering process. That might have to wait until after Christmas....given some likely arrivals on the big day.
In the meantime, time to work on the commander using the world famous 'Marlow Method' (as described here).
So far a coat of grey primer and wash with a coat of 50:50 Vallejo Black Game Color wash (73.201) and Vallejo Glaze Medium (73.596).
ATB.
PS Junior thinks he looks like he's sitting on a cloud meditating.... :smiling5:
Hi Andrew
Those do indeed look good. Had to smile at Junior's "meditating man" - he does look as if he's doing just that. :smiling:
Hi Andrew
Thanks Jim.....I'll pass on your comments to Junior. He has quite a sense of humour and sees things I marvel at sometimes...!
ATB
By calling on his inner zen with Tai Chi he’ll be irresistible in battle Andrew….
He might need it.....
He's in a Cromwell and I have a smattering of Panthers, a couple of Pak 40s, an 88......and of course my King Tiger.... ;) :smiling5: :smiling5:
Apparently, according to a couple of recce commanders I heard giving a talk at the history festival, the tactic used by Cromwell troops was for all tanks to hit the German with HE and try to smash the optics so it was unable to see to fire….or if they were really lucky to set light to the fuel fumes given off by the engine…..not seen any of this in wargames rules though LOL…..
Interesting.... Definitely not on my rules..... And definitely won't be giving Junior the option.....
The other thing I got from that talk was that the German mp40 with the stock removed was the British tank commander’s weapon of choice…..apparently it allowed a better field of fire close to the tank and was easier to store.
