In a way it is right up my street, but at the same time I kind of want to build this simply and fast … For which I should have bought an Asuka M4A2, it turns out
I added texture to the final drive housing:
This is putty that I spread all over it with a spatula (working in small areas, not the whole thing at once), and while still wet I put liquid cement over it to thin it and added texture with a stiff brush. That turned out to be far too rough, so once dry I sanded it down to what I think (hope?) will be a quite acceptable texture after painting
The turret has more problems than I thought. For starters, it has a strangely angular shape on its front face:
Those sharp lines on either side of the front opening should not be there, and if you look closely you’ll see what almost amount to corners just above them, where the light catches, as well as a sharp line at the bottom of the curve between the sides and the roof. A bit of work with a file takes care of all of those:
At the rear, the corners are too sharp, so I filed those round as well:
View attachment 446805View attachment 446806
Harder to correct is that the loader’s hatch is wrong after all, it turned out over on Missing-Lynx. It’s slightly oversize, but I have no problem with that; what is an issue, is that its angle is very much off. Here is the angle the hatch on the model is set at:
That should be 34 degrees, but I make it 53 … but I have a hard time finding a good way to correct this without it being a lot of work.
