Tim’s Trumpeter KV-7 in 1/35
I've never heard mention of doing that before, definitely one to remember Tim .
I must admit that compared to the rest of the tank they seem overly complex and fragile John. Not like the usual utilitarian Russian stuff at all. No need for the screw tensioner, a simple storage hook would have done the same job.
Or even an eye?
Tim,
That's turned out very nicely despite the paint problems and the tow cable idea was genius!!!
As John says, will have to remember that!
ATB.
Or even an eye?
There is already an eye on the cable though? Perhaps a shackle arrangement like the towing points would have been better? Anyway, the screw tensioner is not a great solution to my mind….
Sorry, meant shackle - put it down to zero coffee so far this morning:surprised::smiling3::smiling3:
Tim,
That's turned out very nicely despite the paint problems and the tow cake idea was genius!!!
ATB.
Cheers Andrew, it’s just a simple solution to a simple problem that I thought might be of interest…
Well, she is done.
Enjoyable build. No real vices, but looks a bit dull when finished. I’m not a dio builder , but do wish I’d put a crew figure in her…..hope she passes muster :thumb2: Are we supposed to put finished images in a group build folder?
Hi Tim
That idea for fixing the cable is good. Much more robust and still looks as it should.
That is a cracking build. You've done a great job varying the paint tones. Adds interest.
I love the finish on this one Tim. Great contrast on the modulation.
Hi Tim
Cheers Jim. Really glad you like it :thumb2:
Cheers Jack. Really simple to do. Spray the dark dark from below horizontal, making sure to hit all the undersides. Spray the actual body colour from about 45 degrees above horizontal, so it leaves shading, and finish by dry brushing with a lighter colour to bring out detail and texture.
Wow Tim, just playing ketchup and see you're done...This 'Beastie' has turned out very fine Sir!!! I can agree it looks a little plain as it was a prototype, but the color finish is most excellent. I especially like the finish on the tracks. Very realistic. I still have to paint mine though. A figure would definitely set it off as you said. Top job!!!....
Na Zdorovie (Prost)
Allen(ski) Pres.
RBB Paint Factory #69.5
Yummity scrummity Tim, paint looks like a heavy duty work horse should me thinks! ⚒️
Na Zdorovie (Prost)
Allen(ski) Pres.
Cheers Allen. Glad you like it. The recipe for the tracks is in the build log if you want to steal it ;)
Glad you like her Rob. Thanks for the kind comment ref the paint. Trouble is, she was only two weeks old at the time of the trials, so she really shouldn’t look that careworn :disappointed2:
Very nice model, I like it :) It manages to look both cartoonish and underarmed, somehow …
Very nice model, I like it :smiling3: It manages to look both cartoonish and underarmed, somehow …
I’d agree on both counts Jakko. It really does have that “back of a fag packet” design air doesn’t it….
