Petes Spitfire GB. Chat thread.
Unless an anniversary or such aund unlesisi otherwise stated, the start date is always the first day of the starting month and the end date thek last day of the final month. Found it keeps it simpler to follow, Bruce. I mean Tim.
Guys.... Help required please!!:anguished:
I`ve bought a cracking set of internal cockpit decals for my entry into the Mossie GB..... Bear with me,it`s relevant!!......
Anything similar around for a Mk IX please... trawled LOADSA places..... can`t find any:flushed: .....
... Any suggestions would be much appreciated,because,not being a flying fing builder ...... i need all the help i can get!!;)
Cheers in advance,
Andy
Cheers in advance,
Andy
Andy,
you mean 1/48? If so, Eduard do a fancy resin/PE in their LooK range https://www.eduard.com/eduard/spitf...sttype=search&searchparam=spitfire mk.ix look
Eduard also do a pre coloured PE set of seat belts and IP for a nine Andy…
It’s what I’m using on my twelve…..bit cheaper than the 3D printed IP.
Cheers in advance,
Andy
you mean like these?
https://www.eduard.com/eduard/3d-decals/spitfire-mk-ixc-late-version-space-1-48.html
I’m going to change mine to a 1/72 Academy one I just like them better. Ordered it today I’ll post it when it gets here.
Whilst I was painting my USS Tuscaloosa, I was thinking on what I was going to build next - I'd forgotten about the Spitfire GB ( memory isn't what it used to be! ) - so kickoff on Wednesday - just about ideal timing, as my floaty thing will be nearing completion
Glad you got a "Kickstart" there Dave......
Will be great to see you chipping in..:hugging-face:.
... I`m trying to finish my current 223 build asap so i can get started on it:thumb2:
Chocks away!!
Good Luck all, an iconic plane indeed. Best leave it to you all this time .
