Latest Acquisitions (2022)
How does it sand though John. To date I’ve found acrylics just tear if you need to do remedial work. Not an issue on my little blokes, but an essential quality if you work on things like aircraft or civilian cars…..
Tim before today I would have said no idea, but I cut back the building front on the diorama with some 400 git wet and dry, both wet and dry. Seemed to be ok as long as I didn't press too hard.
I`ve been after a better display case for a while now,narrowly missed out on a couple the last 6 months or so.
However,my luck changed on Wednesday when my solitary bid of TEN QUID actually won one!! Even better...... it was "Collection only"..... Buckfastleigh...... which is just 10 miles down the A38!!:thumb2:
Just picked it up,it needs a bit of a clean but Hey,i can cope with that!!.........
Ere tis.......
...... YEP..... just TEN quid:dizzy:Feeling rather pleased with myself :cool:!!
Andy,(That`s not where it`s going BTW,the pic was taken in situ at the sellers)
Wow fantastic Andy , Cohan's new vertical high rise ? Love to Rach from us both .
Errrrrrrrrmmmm I don't think I would want the job of masking the canopy on that little aviation "nightmare" :tongue-out3:
Yeah, you're spot on there Rick..
Problem is with me,I tend to think,"Hmmm,that could be tricky, but I'll overcome it.......
Then get it anyway and suddenly think.......,"Oh s***,how am I gonna do that?"......
.... Not stopped me adding to the stash yet mind!! :)
.... Not stopped me adding to the stash yet mind!! :smiling3:
I know what you mean there Smitty, In my stash He 111, Ju 88, Arado 234b etc. etc. And no pre made masks in 1-87 so they languish.
Bought this from discount bin. Even if it is 12 years old, this book is a gem!
Somehow after walking past Mr.Models stand at the Cosford AIrshow my 18yr old son had talked me into buying this; building it, painting it and then 'gifting' to him when finished. only £24.99 so not that expensive and it looks a good kit and build ( have checked youtube). Havent built any plastic for a couple of years so should be fun !
Steve, great kit but I think you need to have words with your son...... First it's a model, then it will be a car and before you know it, it will be a house!
Hi all
here are my latest acquisition - pins but not just any pins:
these are pins from Watkins & Doncaster which are designed for pinning insects. They are strong and very thin, thicknesses of : 0.42mm, 0.32mm and 0.25mm.
a little while ago I bought some 1/72 scale figures and these will be used to pin the figures to the diorama base, and to pin together parts if I convert any of the figures.
Peter
Hi all
Peter
Interesting.... Might have uses for me as 1/72 is my usual scale!!
ATB.
Hi all
Peter
Wow! I thought 0.5mm was thin enough (I was thinking of mechanical pencil lead refills size).
Are your pins made of special steel? Are they bendable without breaking?.
if you pm me I'll send you a dozen or so - they come in packs of 100 each so I have one or two spare!
Peter
Very generous Peter.
For info…..Lace making pins are another source of thin strong pins. I bought some twenty odd years ago for assembling railway locomotive valve gear and am still using them for odd jobs. They come in a variety of materials, diameters, and lengths.
