I see, the surface finish difference, that was something hard to predict with the same manufacturer.Thank you for the compliments, Andrzej,
The 3 primers was an experiment and the result is partially satisfactory: where I used the white (the tail) the difference is visible while there is not a significant difference between the red primed and the black primed surfaces. Another difference is that Tamiya white primer finish is less smooth than the red and the black ones; I think I will use it for land vehicles in the future and not for aircrafts.
Andrea
Yes. Tim; me too I thought it was a little smaller than this.Blimey, bigger than expected……if you build more like this you will need a bigger spray booth Andy….
Thank you, Colin. In fact, there's very little black; German panzer grey and NATO black in various percentages are the main ingredients of that livery; black is present only on the underside but just a pair of drops.Great work Andrea. Sometimes black can be too black, but not here. Your tonal variations are spot on to me.
