1/72 Tamiya kit - should I complain about these wings?
adt70hk
Hi all
I'm about to start my Mossie GB kit and have noticed these marks on the wings.....should I worry and complain? Or will I be ok?
I can't feel anything with my finger or nails when I run over them, the wings don't seem obviously distorted and both of the other Tamiya Mossie kits I have from the same range also have identical marks - for better or worse.....
ATB
Should be fine if you cant feel anything,puff a bit of primer over one of em see what it looks like.
With Mark on this one. If it’s OK under primer it’s OK :thumb2:
Looks like plastic flow marks from the moulding process to be honest. Quite common in kits, and more noticeable with some plastic colours over others.
Could possibly be stress marks caused as the plastic solidified ??? Total guess.
Thanks guys. I'll try to whack some by primer on at the weekend and see what happens.
Just flow lines in the plastec, shouldn't be a problem.
Andrew,
Yep - purely aesthetic. These are mould flow lines and are even more evident with polymers that have fillers in them (e.g. talc, glass fibre and so on)
They will not be evident once you have primed, they won't be a source of structural weakness and they will not result in any adhesion difficulties.
They just give an engineer a clue as to how they have laid their tooling out :smiling:
Enjoy the build
Andrew,
Enjoy the build
Thanks John....and another great lesson learnt! Just what this forum is about!
